No reading from O2 sensor 1
Old Jul 14, 2025 | 06:21 AM
nellis003's Avatar
nellis003
Hi All,
I've been trying to figure out a persistent issue on my 2009 Clubman non-S. It bogs down when driving over 2,000 RPM, and the trouble codes have pointed towards MAF sensors and O2 sensors. I've replaced both O2 sensors and the MAF, but when I took it for a test drive with the ODBII reader attached and sending data to my phone, the O2 sensor shows no reading. I drove it for about ten minutes, so I assume it was heated up enough.
Before I start throwing more parts at this, can anyone suggest a solid procedure for testing the O2 sensor?
Thanks,
Nick
Old Jul 14, 2025 | 05:08 PM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
Post all fault codes that have returned.
Old Aug 1, 2025 | 08:46 PM
nellis003's Avatar
nellis003
I'm getting P0136 and P115C.
Does anyone have a diagram that shows the function of the wires leading to O2 Sensor 1? I want to try a couple diagnostics but am having trouble determining which is which. Wires to the sensor itself are Red, Black, White, Yellow, and Grey. Wires on the other side of the connector (to the ECU) are Black, Orange, two White, and two Yellow.
I found a diagram that shows all the pinouts to the ECU and confirmed that the wiring from the connector to the ECU is good. At the O2 connector, I traced the wires to B15, B16, B17, B27, B28, and B30 on the ECU. Can anyone tell me the functions of each of those?
Thanks,
Nick
Old Aug 2, 2025 | 06:06 AM
Maybe, maybe not
Community Builder
Your troubleshooting would be more focused and accurate if you used a code reader that reads BMW codes.
For example:
-Three different BMW fault codes can trigger generic code P0136
271C DME: Fuel-supply system
273A Oxygen sensor behind catalytic converter, electric
2A7F DME: DMTL leak diagnosis pump, activation
-Two different BMW fault codes can trigger generic code P115C
2775 DME: Combustion misfires, cylinder 3
1. If problem is present with mixture, VANOS, lambda control/oxygen sensor, camshaft control, injection valves, then repair these faults first.
2. Spark plug visual inspection (cracked ceramic insulator, black electrodes, electrode gap, etc.), replace as indicated,
3. Wiring harness electrical check, check contacts (corrosion, insulation damage)
4. Check ignition coil for corrosion, cracks, interchange coils between cylinders as indicated, conduct road test with full acceleration and note whether fault in fault memory migrates, replace ignition coil as indicated.
2B5C DME: Air-mass sensor, plausibility
1. Plug in HFM
2. Check connections/plugs (corrosion, water, etc.) between HFM and DME (CMI-240, CMI-209 and CME-114)
3. Replace sensor as indicated
Old Aug 2, 2025 | 06:33 AM
Maybe, maybe not
Community Builder
Just an FYI:
The O2 sensor fault signified by generic code P0136 is for the 4-wire post-catalyst oxygen sensor (O2 sensor 2) not the 5-wire or 6-wire pre-catalyst oxygen sensor (O2 sensor 1).
Seaswood
May 25, 2025 09:41 AM
ijourneaux
12
Apr 8, 2020 08:17 AM
Rastoff
Apr 4, 2018 07:28 AM
micromini234
Jul 14, 2014 07:45 PM
dominicminicoopers
Dec 17, 2005 03:34 PM
