R50/53 R53 -2004 Front engine mount ( passenger ) and Belt tensioner torque question
Old Jul 4, 2025 | 05:06 AM
Mforce's Avatar
Mforce
Hello,
It's 4th of July 2025, I got question again well not really question I just need to verify these before doing this today. Plan is replace my R53 Belt Tensioner and as well the front engine mount, yes the hydraulic one.
I am reviewing what bentley says.. am I correct on these?
Engine Mount:
R53
R53
About #2 - it says 74ft-lbs isn't this too high? maybe a typo? these bolts on to the top engine block, and I think the engine block is aluminum not cast iron.?
Belt tensioner:
R53 - Belt tensioner
You guys know what's the torque for number #6?
Happy 4th of July to all... I will be having my beers and BBQ while doing this. Thanks in advance.
Old Jul 4, 2025 | 06:48 AM
noodlesandsam's Avatar
noodlesandsam
The block is cast iron. The head is aluminum. Those values look reasonable.
Old Jul 4, 2025 | 06:06 PM
Here2Go's Avatar
Here2Go
NAM Community Team
I believe there is no torque value for #6 (?) (tensioner diagram). But I think I had read somewhere= 9# lbs. I will however, tell you that they can break off at the hex fairly easily. From my experience: Just crank it down nice and tight.
Old Jul 5, 2025 | 03:36 AM
Mforce's Avatar
Mforce
It's the same bolt as #5 only shorter. I just did hand tight on these, it won't fit my torque wrench. I went back to default standard length open and close wrench then handtight it from there., not too loose and too tight., I am worried about the aluminum where you bolt these.
Old Jul 5, 2025 | 03:48 AM
Mforce's Avatar
Mforce
Tnx, man. True I saw it.
JeanPaul
Jan 19, 2021 05:05 AM
89325iturbo1
May 11, 2019 10:03 AM
patsum
Oct 11, 2015 11:25 AM
Grahams315
Mar 18, 2013 05:57 PM
tr6drvr
12
Nov 14, 2008 07:16 PM
