R50/53 Help ID this blue adjustable tensioner?
Old Oct 11, 2015 | 10:46 AM
patsum's Avatar
patsum
I just picked up a used 05 R53 and the belt squeaks and squeals just a little bit. I thought I would check out the belt and replace it but was greeted with this adjustable looking blue tube attached to the factory tensioner. Can anyone ID it? and what is the best way to go about removing it to install a new belt? I'm assuming this puts constant pressure on the failed tensioner to keep the belt tight. The issue is that it looks like it is almost crooked or pushing the tensioner and its pulley to the side by a small amount. Or maybe this is proper and I have never seen it before and need to simple tighten or loosen it to adjust the belt.
Thoughts? I have had no problems replacing belts on my other R53s with stock tensioner setups.
Old Oct 11, 2015 | 11:09 AM
MINIAC's Avatar
MINIAC
Atermarket (LOTF or TSW) engine damper?
Old Oct 11, 2015 | 11:16 AM
patsum's Avatar
patsum
It IS an LOTF 05-06 damper kit
It doesn't mount o the tensioner at all then.... interesting... thew car is 100% bone stock minus this one piece.
In theory to change the belt I could just unbolt this from the frame and be good to go to replace the belt.
Here is another one I found. Mine is mounted the same way. Supposedly makes takeoff smoother instead of lurching...
Old Oct 11, 2015 | 11:25 AM
bavmotors's Avatar
bavmotors
Yea I've seen these, how well does it work?
skmboardchik4lyf
Feb 28, 2016 11:28 AM
DrFraserCrane
Oct 7, 2015 04:04 AM
makg
Sep 24, 2015 11:10 AM
patsum
Sep 14, 2015 07:15 PM
shahriar35
Sep 12, 2015 08:31 PM
