R53 - Lower engine mount ( rear ) torque specs
Old Jun 4, 2025 | 07:12 PM
Mforce's Avatar
Mforce
Hello,
I am planning to replace my R53's lower engine mount this coming weekend.
Do you guys know the torque specs of these?
#11 = ?
#10 = ?
#8 = ?
Please see below.
I've been reading this thread but it looks like it's not really a sureshot values.
R53 - lower engine mount torque specs
Thank you.
Old Jun 5, 2025 | 10:08 AM
cooper48's Avatar
cooper48
#8 and #11 are 74 ft. lbs.
#10 is 28 ft lbs.
Old Jun 5, 2025 | 05:18 PM
Mforce's Avatar
Mforce
#10 is 28 ft lbs.
These are factory MINI specs right?
... ok thank you very much.
Old Jun 5, 2025 | 05:29 PM
Mforce's Avatar
Mforce
As a thank you here's the final image so if someone needs it, here you go. Let me know if it's wrong.
Old Jun 5, 2025 | 05:42 PM
Mforce's Avatar
Mforce
I am curious why MINI decided 74ft-lbs ? from the looks of it -- it does not carry heavy weights just side twists and up\down motion. Isn't this too high?
Old Jun 6, 2025 | 05:24 AM
deepgrey's Avatar
deepgrey
It’s an M12 bolt of presumably decent grade with good thread engagement bolted into steel, if memory serves. Seems like a reasonable value.
Old Jun 6, 2025 | 09:49 AM
Mforce's Avatar
Mforce
I was expecting somewhere 45ft-lbs to 55ft-lbs., I guess that's what MINI\BMW engineers got when they calculated the thing.
The 28ft-lbs that one is expected, it's bolted on to the softer aluminum pan.
Old Jun 6, 2025 | 09:59 AM
Mforce's Avatar
Mforce
Va_R53
Aug 8, 2018 06:28 PM
Jan 5, 2017 07:57 AM
Jan 5, 2017 07:47 AM
