R57 Convertible Top Side Bracing
Old May 20, 2025 | 08:22 AM
JAMADOR's Avatar
JAMADOR
Noticed as I was wrapping up the vinyl window install [https://www.northamericanmotoring.co...ml#post4695601] that the plastic bracing on the driver's side is coming apart.
See this part at ECS: https://www.ecstuning.com/b-genuine-...p/54347276922/
On the install of these, does the top need to be operated to get this done? I ask because with my FRM being intermittently in a fail state, I'm currently unable to lower the top [nor the door windows].
Can these braces be installed with the top up & latched? I noticed them being damaged when having the tailgate down & propping the rear of the top up with the kickstands. Does this give enough slack/access to fix these without having access to move the full top?
Old May 20, 2025 | 08:30 AM
Hello, Here is all info to do it. Looks like top down. But you might be able to pull it out and get behind with top up?
https://www.ecstuning.com/Search/Sit...h/54347276922/
https://www.reddit.com/r/MINI/commen..._broken/?tl=sv
https://www.mini2.com/threads/rear-s...k-damp.198855/
workshop-manuals.com/mini/cooper_jcw_convertible_(r57)/l4-1.6l_turbo_(n14)/body_and_frame/roof_and_associated_components/convertible_top/convertible_top_canvas/component_information/technical_service_bulletins/customer_interest_for_convertible_top_canvas/m540209/sep/10/body_soft_top_cover_separated_from_body_at_c-pillar/page_1704/
Old May 20, 2025 | 08:37 AM
JAMADOR's Avatar
JAMADOR
I read the mini2 thread & the one on here, but not a lot of photo documentation of the process.
Luckily, mine doesn't seem to be leaking when it rains, so it's not urgent.
I hosed it down pretty heavily after finishing the window replacement and no leaks that I could see.
Not really looking forward to the $4-500 for a new FRM, plus an hour labor [local indy shop] to program. Will be nice to have full functionality again, though.
That last link to the workshop manual is much more insightful. I'll have to take a look at it & see how accessible it is with the top up.
Old May 20, 2025 | 09:00 AM
Ok, yep thats all the info i have since the part is a weird warranty fix part that we found. Good luck and post back after the repair.
Old May 20, 2025 | 09:01 AM
JAMADOR's Avatar
JAMADOR
Thanks ECS, that last link was very helpful. Now to determine if I can get it done with the car in its current state.
Still holding the tiny hope of getting included in the FRM recall & save myself a fair bit of $$$
Just Krusen
R57 :: Cabrio Talk (2009+)
33
Jul 31, 2025 12:42 PM
dandrewk
Oct 2, 2009 01:13 PM
SkyZero
Sep 1, 2008 03:27 PM
DustinDallas
Mar 6, 2005 01:49 PM
