R56 power steering replacement??
Old May 9, 2025 | 05:29 PM
uneze's Avatar
uneze
helping some friends with a 2009 Cooper s Turbo / I believe it's an n14/r56.
they had an overheat due to a water pump failure so we got it going again and after one short trip to the store the power steering went out.
We've triple checked all electrical connections and the fuse is fine. thinking that the overheat may have cooked the pump.
thing is we've looked EVERYWHERE online for someone who's talked about it and can't find a single video.
I have a 2004 base model and have done everything to that car myself. all we can find are videos and talk about that particular pump which is much different.
have tried searching this forum and still coming up empty handed. hoping that there's a huge cache of into and i'm just missing it. would love any direction, links or anything.
I've gotten a good look at it form underneath and I think i could get it out without removing rack and pinion etc... really need to know what other downstream problems we might run into to decide it this is something i even wanna attempt.
much thanks in advance!
Old May 10, 2025 | 06:53 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
These cars have electric power steering. There is no pump.
Old May 10, 2025 | 07:09 AM
uneze's Avatar
uneze
right that much we've gathered. - I should have said steering motor, my bad. - still looking for any insight into what needs to be done to mate the Mini computer with a new motor / scanner type etc? can it be done in the hidden menu etc? / can these motors be refurbished? maybe replacing bad circuit components etc?
Old May 10, 2025 | 08:40 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I would check the wiring connections first. Maybe something didn’t get plugged in correctly.
Old May 10, 2025 | 09:14 AM
uneze's Avatar
uneze
yup - the plugs all lock in. we didn't touch any of that while doing the coolant system repairs. Any place you know we could get a wiring diagram to i could send power directly to the motor switch to test? there's apparently a continuous high amperage line, like on a starter, and another smaller on opening the circuit to get it to run.
Old May 10, 2025 | 12:05 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
This is the wiring diagram for the steering box, but it all CAN bus stuff, so not much to go by….
Old May 12, 2025 | 10:03 AM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Any insightful steering-related fault codes?
Old May 13, 2025 | 07:45 AM
When doing the suspension work people knock the plugs off or damage the plug. Yep scan it with a indepth scan tool
https://www.northamericanmotoring.co...it-wiring.html
Old May 16, 2025 | 04:27 PM
uneze's Avatar
uneze
yes it's showing the steering warning light on the dash. Need to check codes again and will get back.
Old May 16, 2025 | 04:35 PM
uneze's Avatar
uneze
I don't have a high end scanner but need to get a BMW specific one, I am told, that can reset the adaptations in a 2004 mini I'm stuck with. I figure what ever does that will prob be good for this too. any suggestions?
Old May 19, 2025 | 07:42 AM
I have the schwben tool and carry them in the MINIs. https://www.ecstuning.com/b-schwaben...020sch01a~scf/
mini_geoff
Jun 8, 2017 12:51 PM
MiniOnDaRun
Oct 22, 2014 08:32 PM
orvillespooner
Mar 13, 2014 09:02 AM
xbritt
19
Jan 9, 2009 07:04 PM
MikeB035
Jul 3, 2007 02:52 PM
