R50/53 R53 Oil system
Old May 4, 2025 | 10:55 AM
NATHANR53's Avatar
NATHANR53
R53 Oil system
Since fitting a ported and polished BVH and cam, my rocker arm dampeners make a top end clicking sound because they keep seizing.
Ive free’d them up once in an ultrasonic cleaner and then soaked them in clean oil. Cars got fresh oil and filter.
I also bought a reconditioned oil pump, crank case cover as a bolt snapped in it, when doing timing chain.
Just wondering what could be causing the issue before spending money on new rocker arm set and potentially causing the same issue if there is an issue not picked up by sensors in the oil system.
However this ticking sound is causing an issue with compression and wouldn’t mind getting it sorted.
https://youtube.com/shorts/MJx2H37Cx2o?si=OmChn5we_DOYlVQu
Thank you for your tips and ideas. Regards Nathan
Old May 4, 2025 | 12:26 PM
Nervos's Avatar
Nervos
"reconditioned oil pump" - why? New ones are not that expensive (check out Melling M480)
Old May 4, 2025 | 01:49 PM
NATHANR53's Avatar
NATHANR53
Reply: Nervos
Hi mate, thanks for your message. I bought one reconditioned due to one of the belt tensioner bolts snapping off in the case, removal wasn’t happening and I needed it being put back together so the engine wasn’t open to the elements as it was fitted to the car.
Is there a normal oil pressure figure I could look at through an OBD Reader and compare to see if the reconditioned crank case cover & pump is an issue?
Old May 5, 2025 | 03:48 AM
deepgrey's Avatar
deepgrey
The R53 does not have an oil pressure sender.
Old May 5, 2025 | 05:27 AM
NATHANR53's Avatar
NATHANR53
It has an oil pressure sensor? Do you mean I won’t be able see the pressure reading?
Old May 5, 2025 | 05:41 AM
deepgrey's Avatar
deepgrey
The oil pressure switch mounted to the oil filter housing triggers the idiot light on the dash at a set pressure (I forget what it is, but it’s very low), and that’s it. So, no, you can’t pull oil pressure from the OBDII port.
Old May 5, 2025 | 07:01 AM
NATHANR53's Avatar
NATHANR53
Ahh right, what would your advice be to cover all basis alongside new rocker arms to ensure oil pressure isn’t a problem in the future if there’s a chance it could be right now?
Old May 5, 2025 | 09:51 AM
cooper48's Avatar
cooper48
What's the lift on your cam?
Old May 5, 2025 | 11:39 AM
NATHANR53's Avatar
NATHANR53
Hi mate, been a minute. Hope you are well.
Camshaft details.
Camshaft details.
There’s no wear on them or the spark plug cylinders. And last time the ticking went away for a short while when I ultrasonic cleaned the rocker arms and then soaked them in fresh oil. But didn’t last long. Leading to thinking it’s the dampeners. However wondered if anything could make them go bad like oil pressure and how I could make sure it doesn’t happen again when I buy new rocker arms.
Old May 6, 2025 | 01:04 PM
deepgrey's Avatar
deepgrey
I’m not really the best person to ask about that, but as far as monitoring oil pressure, some people install a fitting on the oil pressure housing so that they can add an auxiliary oil gauge and sending unit. I’ve got one that I keep meaning to install. That said, you didn’t mention having the idiot light for oil pressure come in, did you?
Old May 6, 2025 | 01:29 PM
NATHANR53's Avatar
NATHANR53
No not had the idiot light at all, but not sure why the rocker arms have seized back up unless there’s an oil pressure issue or a blockage in one of the oil galleys in the rocker arm shaft. I’ve ordered some cleaning brushes and will have a go at cleaning it thoroughly along side any other oil passages through the cylinder head before buying new arms. Think I’m going to ping the spark plug cylinders aswell while I’m at it just to cover all aspects.
losing hope tbh, it’s one thing after the other lmao.
just wanna drive it with no issues for a minute 😂
Old May 6, 2025 | 08:36 PM
2out2sea's Avatar
2out2sea
I had the same noise. I just jumped in and bought a new motor, but discovered after pulling the old 60k motor that the cam was indeed hitting the spark plug tubes. I'd check there first. Just my .02.
Old May 12, 2025 | 04:42 PM
NATHANR53's Avatar
NATHANR53
When I take the rocket cover off and rocker arms, I’ll give all the journals a clean and tap the spark plug tubes and check for wear.
Unsure if heat and centrifugal forces after expanding is what’s making them hit, but it makes the noise from cold and I checked clearance on fit of the cam and the lobes didn’t make contact at any point.
I’ve replaced all the filter housing & cooler seals on Friday just passed.
phone
Jul 19, 2023 01:49 PM
mini-is-for-me
Mar 12, 2020 06:16 PM
fitchesbass
Mar 22, 2018 12:52 AM
shbiv
May 23, 2016 12:48 PM
olson187
Aug 22, 2014 07:54 AM
