R56 Strut top mount bolts
Old Apr 11, 2025 | 10:19 PM
minifanboy's Avatar
minifanboy
The bolts appear to be moving, enlarging the holes they go through. Uh oh. Only on the driver side.
Googling for information has been exceptionally difficult as the keywords bring up all sorts of related issues. I've seen dozens of pinch bolt threads lol.
I presume this isn't good. I am planning a shock + camber plate upgrade for the front soon - should I be accelerating those plans?
Old Apr 11, 2025 | 11:30 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Those holes are pre-formed like that. While it does look like they moved, there is a little bit of "slop" in those holes to allow for minor camber adjustment. (the max camber adjustment on those slots is about ±0.5°)
Get the car firmly on the ground. loosen those nuts, then re-torque them. Should be fine after that.
Old Apr 11, 2025 | 11:43 PM
minifanboy's Avatar
minifanboy
Got it - I was unclear if it was normal or some mod someone did or some deforming which had happened. I did have the car aligned last with the instructions "I want the most aggressive profile possible, I don't care about tire wear".
Thanks!
Old Apr 12, 2025 | 05:10 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
It’s common to loosen those bolts, pull the plastic alignment pin, and push them in as far as they will go. Should get you slightly over -1.0° negative camber on each side. Really, that’s not enough to cause undue wear, and it gets you ever-so-slightly better handling. If you can get -2.0° negative on each side, you’ll be about what the GP2 came with. Dial the toe in correctly, and you’ll have a great handling car with minimal tire wear. Match the rear to the front, and you’ll have a great handling car.
Old Apr 12, 2025 | 09:29 AM
Raymo2u's Avatar
Raymo2u
If you are concerned about wear and hole stretching, you could always get a strut brace. Even a cheap one would help reinforce the mounting area on each side.
I bought an ebay flat strut brace but it wouldnt fit because of my intake, I kept the mounting plates for this very reason....the potholes in my area can be pretty bad.
Old Apr 12, 2025 | 01:03 PM
Gubi's Avatar
Gubi
The R53 had issues with the strut towers mushrooming and you could get stiffening plates for them. That was fixed in the R56, and from everything I've heard the R56 cars also don't significantly benefit from a strut tower brace for stiffness.
As long as those nuts are torqued to spec OP should be fine. As Nik noted it looks like they just moved the strut tops inwards in the adjustment slots to maximize camber.
Old Apr 13, 2025 | 04:45 AM
Seaswood's Avatar
Seaswood
I replaced the struts with Monroe the OEM caps do not fit, do I need to use Monroe caps top of fwd struts?
Old Apr 14, 2025 | 02:38 PM
JAMADOR's Avatar
JAMADOR
threaddrift
Did @njaremka get a new car
Old Apr 14, 2025 | 02:41 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Originally Posted by JAMADOR
threaddrift
Hehe….
https://www.northamericanmotoring.co...ml#post4693232
Old Apr 14, 2025 | 04:47 PM
JAMADOR's Avatar
JAMADOR
Well, don't be a stranger over here
Old Apr 15, 2025 | 03:50 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I’m not going anywhere….
Old Apr 15, 2025 | 07:26 AM
JAMADOR's Avatar
JAMADOR
I don't venture outside of 2g much. So if it weren't for the updates sig line, I'd have missed it.
Did the Clubbie go away for the big boy?
JAB 67
Suspension
Jun 11, 2019 02:05 AM
ksminiman
Nov 6, 2017 10:18 AM
BillyCuth
Suspension
12
Jul 30, 2012 01:36 PM
navybsn
Suspension
Jul 24, 2009 12:36 PM
mataku
Suspension
14
May 24, 2005 08:38 AM
