Radio silence
Radio silence
Not sure if my title makes sense...
However,,, I think I may have an issue with my factory Alpine radio/head unit. With the car off/not running, I get static free and clear radio reception. But as soon as I start the car, I begin to lose radio reception and becomes more static as if out of range from the radio station. Is there a cause or solution to this? Has anyone found or installed a frequency booster to help mitigate poor reception?
I prefer to keep my factory head unit (maintain the Mini's original factory equipment).
Thanks in advance for any recommendations or advice.
Yes - NGK blue spark plug wires w/stock factory coil pack.
Edit: I may have the OEM plug wires stored in box somewhere. If I can find them I'll give it a shot and swap them out to see if it makes a difference.
Thanks.
Thanks.
@Here2Go How old is your Antenna? assuming your on the original.
I replaced my antenna and base due to it rotting out creating a water leak. Instantly better reception, and less interference. NOW... these things are a small fortune so be mindful of that. The reception however does not compare to that of any other vehicles i have owned and is still complete crap lol. There is also still slight interference with background noise. I have a Pioneer double din installed, all aftermarket speakers and AMP and still get this static interference. Let me know how you make out, curious to find a solution that can eliminate this completely!
@mrbean Interesting suggestion. My alternator is 15 years old but still charges (amazingly),14.3 volts. Battery is 2 years old. But will try to remember your suggestion when I do my timing chain.
@Scoobaru2010 - Coincidentally, I've just replaced my antenna last February 2024(?). The rubber base had a small tear. It didn't seem to effect radio signal. It was merely for aesthetics.
I did replace the head unit with a really nice 05 (or 06) salvage yard find about 4years ago. Definitely a noticeable difference compared to my original 04 head unit. Up until now, I've always played music from my phone or Mp3 device and hadn't really noticed until recently having discovered a couple of radio stations that actually play my preferred era of music. Having replaced my head unit back then - I probably should check to ensure that I properly seated the antenna wire.
Will update if I discover anything relevant.
Well wouldn't you know?
As it turns out; the static is caused by my USB/Bluetooth device plugged into my cigarette lighter.
From the moment I unplug it from the cig lighter - the static immediately dissappears and I get clear static free reception with the ignition on and car running.
Uncle-Al
R59 :: Roadster Talk (2012+)
Aug 14, 2023 08:09 AM
FirstminiS
Feb 9, 2010 02:38 PM
