Navigation & Audio 05 Canadian MCS with HK - XM Direct issues
Hi There
If someone could help me out here before I remove the entire rear panel assembly I'd appreciate it.
I have a Canadian 05 MCS with HK, I've been up and down the wire loom, taken all the tape of and I don't see any evidence of the CD changer control cables.
I see a cable loom which seems to be plugged into the HK unit, and I think there might be another going in towards the passenger door.
If anyone in Canada has an 05 MCS, can you see if the CD changer ends are readily visible?
My luck the guy who built my car is a neat freak and hid all the non used ends
Thanks in advance
Thanks in advance
Well that was stupid to assume something....
It appears that if you have a Canadian spec car, and did not order it with the CD changer, you do not get the wiring pre run. It will be custom work at the dealer.
I suspect I'll be selling the blitzsafe interface shortly....
Steeroidz
Aug 29, 2018 07:41 AM
arf88
May 31, 2016 03:07 PM
