PS Pump-like Whine
Old Mar 10, 2025 | 04:44 PM
JAMADOR's Avatar
JAMADOR
PS Pump-like Whine
Mostly noticeable at lower RPM, and much more pronounced with the AC on. Variable with RPM change.
These don't use a belt driven PS pump, right? Hoping it's not a compressor issue, doesnt affect AC performance at all.
Old Mar 11, 2025 | 06:39 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
There is no power steering pump on the 2nd generation engines. Power steering is electric assist. If the sound gets worse when AC is on, then I would suspect AC compressor.
Old Mar 11, 2025 | 07:03 AM
JAMADOR's Avatar
JAMADOR
Ugh, hoping it's not. AC works great [as well as you can expect for a convertible in Houston]
Is there a tensioner or idler pulley in the belt system that could also be the culprit, getting some additional strain on it with the compressor engaged?
Old Mar 11, 2025 | 08:24 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
The belt that drives the AC also drives the alternator....
Old Mar 11, 2025 | 08:35 AM
JAMADOR's Avatar
JAMADOR
I'd assumed a single belt system, was just hoping maybe a tensioner or idler could be the culprit, over a pricier alternator or needing to go to a shop for a compressor replacement [since I can't evac & charge the AC]
rensai
Jan 17, 2017 08:14 AM
cdemarco4
Jul 30, 2016 02:07 PM
jirsty
Oct 6, 2015 07:12 PM
MIKESGREENMINI
May 31, 2013 10:54 AM
JBMCS06
Sep 10, 2005 06:22 PM
