R56 2011 Base, burning oil, soot in tail pipe 0 smoke at all
This one has plagued me for awhile now. It has always burned a little oil sine I owned it as the second owner. Nothing really ever that concerning. Not enough to get too much into it. Maybe about a quarter of quart every month or so. Over time, I started noticing burning a little more than a little bit of smoke on cold starts, especially in the AM. Only about 2 minutes or so worth, and it was quite light in volume.
I started having some odd issues that seemed to be related to a very small and specific vacuum leak. Won't get into all the details with that, but it took me about a year to realize I must have had a micro crack or something in the OEM plastic valve cover. Long story short there, I replaced the valve cover with an aluminum one. Of course, this also meant I changed the PCV valve as well. While I was at it, I changed the oil filter cap as well.
That was in February of this year. I was hopeful everything would have been resolved at this point. However, now I have the annoying problem of burning about a quarter quart every 500 miles and quite a bit of soot at the tailpipe, BUT...no smoke at all. Not on startup, not on idle, not cold or hot. So I am at a loss. I also have no catalyst codes or anything so kind of at a loss as to how this is even possible and what it could be. Anybody seen this?
Mike
Mike
you might want to read through page 4 of kerwooddr's post. He has a justa and had serious issues with the aluminum cover.
https://www.northamericanmotoring.co...ml#post4688315
Precious_Roy
Sep 12, 2017 06:55 PM
Honeybadgers
Aug 15, 2016 03:34 PM
