R56 N18 engine removal - engine stand, hardware etc
Old Dec 18, 2024 | 05:01 PM
pkgmSu2000's Avatar
pkgmSu2000
Hey y’all, I searched with no luck. I gotta believe a thread already exists please kindly link if you know of one…
I’ve gotta pull my N18 engine. I’ve got a hoist crane but no engine stand and no hardware.
if y’all had to do this, could you suggest an engine stand and any hardware and extra supports, etc to accommodate the N18?
many thanks in advance Merry Christmas
Old Dec 19, 2024 | 02:33 PM
pkgmSu2000's Avatar
pkgmSu2000
Bump if anyone knows the weight of N18 engine after removing the manual transmission and gearbox??? Google search came up with nuttin
Old Dec 19, 2024 | 07:16 PM
mkov608's Avatar
mkov608
I got one of these when I rebuilt my N12; It's great engine stand!
https://www.harborfreight.com/search...engine%20stand
Old Dec 19, 2024 | 08:18 PM
pkgmSu2000's Avatar
pkgmSu2000
that one is really nice had my eye on it too. But if only I knew the approximate weight of my engine, sans trans and gearbox, I could get away with something a lot less used on Marketplace…. Guessing we only need 750-1000 lbs for N18
Old Dec 20, 2024 | 03:55 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
If the engine were 750lbs, I would be really surprised. My guess would be in the 250 range fully dressed, less transmission.
This stand is probably good enough:
https://www.harborfreight.com/automo...and-59201.html
Old Dec 20, 2024 | 06:03 AM
pkgmSu2000's Avatar
pkgmSu2000
$99 woo hoo!!!!!!
Old Dec 20, 2024 | 06:34 AM
mkov608's Avatar
mkov608
Yea, that one will do the trick; I'm spoiled, and like the crank handle on the Daytona. Makes it easy to rotate the engine as you work the top/bottom of the block.
Old Dec 21, 2024 | 05:57 AM
DogfaceSGM's Avatar
DogfaceSGM
I bought one from FB market place similar to what Nik posted. It is plenty. It actually turns pretty easy if you lift up a bit on the far end from the pivot.
BTW, I seperated the engine and tranny while it was still on the hoist. Used two saw horses with boards as a table. The tranny doesn't weigh much, I lifted it off the table to the floor.
Old Dec 21, 2024 | 11:36 AM
pkgmSu2000's Avatar
pkgmSu2000
my plan as well remove the trans while on hoist. Thanks all :-)
Old Dec 27, 2024 | 06:36 PM
pkgmSu2000's Avatar
pkgmSu2000
One more bump mates… searched the R56 N18 threads for good how-to engine removal but couldn’t find anything step by step. Anyone got the links for threads or YouTube videos? There are N14 removals on YouTube which I know is a similar engine but not the same. I’ve got the car in front end service mode, radiator removed etc. just an exposed engine sitting there now. Winging it isn’t worst thing in the world but surely there is a good write up somewhere eh? Cheers mates!!
Old Dec 28, 2024 | 06:18 AM
DogfaceSGM's Avatar
DogfaceSGM
Since I removed the engine from my donor car, it wasn't that important so I didn't look for any videos as I have removed engines from other vehicles. When I did, I didn't take any components off the engine.
If I were putting it back in, as I disconnected things I would have used masking tape wrapped around all the connectors and written were it went or what it connected to. there are a lot of little electrical connectors in the engine compartment that are very similar, makes it easier to re-install/connect.
Lou@Prototype-R
Mar 6, 2026 01:16 AM
Yoshimura 1
Aug 8, 2024 01:53 PM
BRracing
Oct 24, 2015 10:07 PM
VX crazy
R58 :: Coupé Talk (2012+)
Feb 7, 2014 05:05 PM
Audiophile_Mark
R59 :: Roadster Talk (2012+)
11
Nov 1, 2012 08:38 AM
