09 JCW R56 Struggling to start in cold + misfiring
Old Nov 28, 2024 | 12:30 PM
dawsonpeterson's Avatar
dawsonpeterson
Hi, I recently fully cleaned out my intake valves as they were fully caked up with carbon. I did this as my car struggled to start and idle in the cold and I was getting occasional misfires. After I put everything back together, the car fired up great and drove amazing (way more responsive). The day after that, when i turned the car on it stalled a few times and when it eventually started it was misfiring like crazy (mostly on 2 and 4). I drove it around for a little bit and eventually got a check engine light plus limp mode. I stopped in a parking lot and turned the car off and on and it completely fixed the misfires with the CEL also going off. Today (the day after that) when I turned on the car it stalled the first 2 times but started and ran fine after that (no misfires). Just wondering what I could do to fix the car struggling to start and what is causing the misfires. The codes I had with the CEL are below.
Old Nov 28, 2024 | 04:16 PM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
2880 suggests a possible HPFP issue. Measure the fuel pressure at the rail.
Old Nov 28, 2024 | 10:30 PM
dawsonpeterson
what am I specifically looking for when looking at the fuel rail pressure?
Old Nov 29, 2024 | 08:36 AM
Maybe, maybe not
Community Builder
For your JCW MINI, you can probably read the rail fuel pressure with a good scan tool. Also read the response at this link.
Old Nov 29, 2024 | 12:46 PM
dawsonpeterson
fuel rail pressure looked pretty good. when my car was fully warmed up it idled at about 900 psi and peaked at around 1800 psi under full load. when i started the car cold, it started around 600 psi and stalled the first time, and when i got it going the second time the pressure slowly increased as the car warmed up till it got to that 900 ish mark i mentioned.
Old Nov 29, 2024 | 03:18 PM
Maybe, maybe not
Community Builder
Consider replacing the HPFP.
Papote
Jul 17, 2023 02:51 AM
Black Forest
May 4, 2023 07:23 AM
P@G
Apr 22, 2021 05:53 AM
redparchel
Dec 4, 2012 10:21 AM
Kwasi-moto
Dec 27, 2011 02:34 AM
