R56 R56 JCW stalls occasionally on cold start
Old Apr 13, 2021 | 12:19 AM
P@G's Avatar
P@G
Hi,
my R56 JCW currently stalls on about every 10th time doing a cold start. The rpm won't go above 600, it sounds like it's only running on some of its cylinders as theres a lot of unburned gas going in the exhaust. When I start again after it stalled or turn the engine off manually and start again, it starts up just fine. Without any problems.
I read some threads about the high pressure fuel pump going bad, is there any way to check/verify this? I did not realize any recent drop in performance.
There are no engine related fault codes saved within the car.
Old Apr 13, 2021 | 04:53 AM
Minifenrir's Avatar
Minifenrir
Get a Mini specific code reader that has live data capture capabilities and monitor the fuel pressure. You need to have the code reader anyway as the Mini is a quirky car as it is and you can't read most important CEL codes with most standard readers. The 2 things every Mini owner needs to buy are the code reader and a Bentley manual
Old Apr 13, 2021 | 05:45 AM
P@G's Avatar
P@G
Thanks for the quick reply.
Yes, if the car has real time data of the HPFP this is a good idea. I will try it.
Old Apr 22, 2021 | 05:53 AM
bugeye1031's Avatar
bugeye1031
Moderator
The cause could be many things, but this is how my car behaved when the hpfp was starting to fail...at about (can't remember for sure) 115,000 miles
imncrxtc
Dec 3, 2015 12:13 PM
AJK
Jan 1, 2012 11:53 AM
AJK
Dec 31, 2011 10:32 AM
Agent.COOPER
Nov 8, 2011 07:32 AM
colea
Aug 4, 2008 06:45 AM
