R50/53 Valvoline Restore and Protect
Old Nov 19, 2024 | 07:18 PM
MoveQuick's Avatar
MoveQuick
Hi guys!
After wanting one for the last 20 years, I'm now a new 2006 Cooper S JCW owner.
Upon purchasing the car, I had the idea that as its about 19 years old, perhaps I would run this new oil everyone's talking about to clean up the engine. So I went ahead and ordered a case of 3 jugs of RockAuto (as they don't sell it here in Canada) Never having ever owned a European car, I was not aware that you're supposed to use Euro spec oil. Or at least I had forgotten that such oil existed.
The oil gets here tomorrow so I haven't put it in the car yet, I figured I would check in to see if there really would be issues from running said oil in the Mini. I don't want to do harm in an attempt to do something good for the car, just a shame to have purchased this expensive oil for nothing haha. Any input would be greatly appreciated, I have a feeling it will be a "try to sell it off" kinda situation, but it can never hurt to ask.
Old Nov 28, 2024 | 12:18 PM
Krunch2020's Avatar
Krunch2020
It’s Fine
Sorry I missed your post. Yes, it will better than fine in your engine. The new API SP oils are superior in many ways to older formulations. Just keep an eye on that dipstick since MINI’s are prone to losing it or burning it.
Choose an oil and stick with it since the different additive packages can cancel each other out.
Old Nov 28, 2024 | 12:47 PM
MoveQuick's Avatar
MoveQuick
Haha well unfortunately for me, only 1 out of 3 jugs showed up and it had leaked out into the box down to just over 4 quarts. So I sold it off to someone who wanted it.Thanks for the info though! Tried doing some research myself but saw some people saying that they wouldn't trust something that doesn't have BMWs certification.
Old Nov 29, 2024 | 08:18 AM
cooper48's Avatar
cooper48
My son works for Valvoline and he swears by this oil (Restore and Protect 5w30). However, any 5w30 synthetic will work just fine in your MINI.
Old Dec 12, 2024 | 04:57 AM
SarahRoss's Avatar
SarahRoss
Thank you so much for the suggestion.
Originally Posted by mkov608
I'm seeing positive results with this oil in my sister-in-laws new (used) 2013 Cooper (Justa) The engine was a consumer (oil). First we tired Fortis Oil Conditioner (A UK product), and it didn't help. I moved to the Valvoline Restore and Protect about 4000 miles ago. I also took an oil sample and sent it to the lab. If the Valvoline is working, you'll see elevated levels of Manganese according to The Oil Geek (YouTube). I'm waiting on the results.
The engine used 4.6 quarts of make up oil in 7500 miles. Then we changed over to the Valvoline product. After the initial 4000 mile run, she's going over 2000 miles before I need to add a quart. Valvoline says it will take four oil changes to remove all the carbon deposits, but we are already seeing a significant reduction in oil consumption.
https://www.youtube.com/watch?v=-IDvx1LtqVM
Thank you so much.
Old Dec 16, 2024 | 05:14 PM
mkov608's Avatar
mkov608
Old Dec 16, 2024 | 06:15 PM
ssoliman's Avatar
ssoliman
im curious to hear about the lab results
Old Dec 16, 2024 | 06:23 PM
mkov608's Avatar
mkov608
Blackstone Labs shows my sample is "in testing" I should have results by the 20 Dec.
Edit 19 Dec; I got the results back and manganese was zero. So, I emailed Lake Speed Jr. and he said "The lack of Manganese in your results does not indicate the Restore & Protect is not working. Not all pump gas contains Manganese, so not every engine would have deposits containing Manganese. Also, Blackstone uses the ICP method to detect wear metals, and that method can only see particles smaller than about 4 to 5 microns. We use the RDE method, which sees particle up to 8 to 10 microns, so that could be another factor here."
As we accumulate more mileage on the engine/oil; I'll update this post.
Old May 17, 2025 | 06:20 PM
Mforce's Avatar
Mforce
So what's the update on the oil consuming\eating issue? Did it reduce overall to ZERO? I saw one review in youtube it fixed the Honda accord oil burning issue.
Old May 17, 2025 | 07:22 PM
mkov608's Avatar
mkov608
Here's the summary of my on going long-term test.
Assumptions: We're using the Craven Speed dipstick ... the one with the 10 holes in it. Assuming the oil levels are linear on the dipstick, each hole represents 3.2 ounces of oil.
1. Vehicle purchased 10 Jun 23: First 2273 miles the engine used 2.25 quarts of oil.
2. We switched to Valvoline Restore and Protect Jul 2024, at 128236 miles. Traveled 2394 miles and used 1/2 quart of oil.
3. The 2d oil change was performed at 132219 miles on 29 Nov 2024, Travel 2155 miles and used 1 quart, 12 ounces. (oil usage went up here)
4. We're on the 3d oil change with 941 miles on the oil and the level is down 3.2 ounces (see assumptions)
I'm not expecting to get to zero oil consumption on an engine with 137k miles on it, but I am pleased with the reduction in oil consumption so far. The trending that really matters will be after the next oil change.
From the oil report, you can see our trending. The first sample (115605 miles) we added 3 quarts when we picked up the car, so there was a lot of make-up oil that probably diluted the wear metal levels. The next oil change was taken at 7229 miles; make-up oil was the same as a full oil change. At that time, we switched to the Valvoline.
Old May 18, 2025 | 03:28 AM
Mforce's Avatar
Mforce
Thanks man. I am changing to Valvoline 5W-30 Restore and Protect today. Mine is R53 2004
Old May 18, 2025 | 10:24 AM
ghostwrench's Avatar
ghostwrench
This might be the best documentation of VRP I have seen anywhere so far.
Although none of my cars have concerning oil consumption issues, I am really interested in the long term results of using this oil in higher mileage engines as my cars are all high mileage. Thanks for posting this! I will be watching for more results.
Old May 20, 2025 | 02:19 AM
mkov608's Avatar
mkov608
I failed to mention that the test vehicle is an 2013 R56 Justa with an N16 engine. I'm using the VRP in all my MINIs, but the 2013 is the greatest oil consumer.
Old May 20, 2025 | 03:16 AM
Mforce's Avatar
Mforce
[QUOTE= I'm using the VRP in all my MINIs, but the 2013 is the greatest oil consumer.[/QUOTE]
did it fix the oil consuming issue? or even made it less? with VRP?
Enduser
May 15, 2011 09:27 AM
lrtrees
Jul 27, 2009 06:17 PM
Miah34
Dec 1, 2007 03:28 PM
SEVEN
General Discussion
Dec 6, 2003 07:45 PM
