R50/53 Bleeding the ABS system
Old Nov 12, 2024 | 08:15 AM
R53Pete's Avatar
R53Pete
I will probably be replacing the master cylinder, hard lines and calipers on the cooper s. Do I need a specific software or hardware to do ABS bleeding procedure? Is there a how to?
Old Nov 12, 2024 | 09:03 AM
Jason Cornelius's Avatar
Jason Cornelius
From Newtis....
Old Nov 12, 2024 | 10:54 AM
R53Pete's Avatar
R53Pete
That seems easy. That is just normal bleeding procedure. How do you cycle the ABS pump to get all the air out? Or the ABS pump doesnt work like that?
On my fords I had to go in a special prodcedure where the computer activated the pump intermittently to clear all the lines of air.
Old Nov 12, 2024 | 11:18 AM
Here2Go's Avatar
Here2Go
NAM Community Team
Certain OBDII scanners like the Foxwell NT 510 Elite include that special function for activatin and bleeding the ABS. I have never done it myself so I apologize for not being able to add much more.
Old Nov 12, 2024 | 02:19 PM
ssoliman's Avatar
ssoliman
inpa will also do it for you
Old Nov 12, 2024 | 03:36 PM
cooper48's Avatar
cooper48
My R53 bleeds just fine with no special circumstances for ABS. Do yourself a favor and pickup a pressure bleed system from Harbor Freight that works with your compressor -- simple and effective.
Old Nov 12, 2024 | 04:43 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
That description from the manual for the front circuit doesn't compute. "Open" should come before "Close"....or am I missing something?
Old Nov 12, 2024 | 06:05 PM
R53Pete's Avatar
R53Pete
But I am planning on changing the master cylinder and the hard lines, both will require the ABS pumps to be cycled and purged.
Old Nov 13, 2024 | 08:28 AM
Tombstone's Avatar
Tombstone
The Harbor Freight pressure bleeder works just fine but, I ended up with a Vacuula bleeder ; the ABS wasn’t affected in anyway…
Old Nov 13, 2024 | 10:57 AM
ssoliman's Avatar
ssoliman
if you open the system (allow air in) then abs activation is needed. if you are just bleeding in new fluid, not necessary. thats what i have read
Old Nov 13, 2024 | 11:32 AM
Tombstone's Avatar
Tombstone
You can bleed the brakes including ABS, however, you can’t let the master cylinder
Run empty, then you’ll have an ABS with air bubbles that’ll require a dealer scan tool
command to bleed out the air bubbles where it opens all the valves inside, etc
Old Nov 13, 2024 | 02:47 PM
ssoliman's Avatar
ssoliman
op is replacing master cylinder
inpa or capable scan tool will do it
Old Nov 14, 2024 | 03:32 AM
adriancl's Avatar
adriancl
INPA bleeding
Can do the job easy using bleeding procedure with INPA K Dcan cable and INPA software.
Old Nov 17, 2024 | 09:21 AM
Tombstone's Avatar
Tombstone
The Foxwell NT-650 Elite works well for ABS also…
Grand-Cayman
Jun 6, 2021 11:20 AM
wilkrod
Mar 19, 2020 07:22 AM
Porthos
May 27, 2014 11:55 AM
Grahams315
Dec 11, 2012 01:14 PM
jeffm5150
Classic Mini Talk
14
Aug 11, 2010 09:42 AM
