R50/53 Manual transmission swap/ engine removal
Old Nov 7, 2024 | 05:06 AM
Tiagovito's Avatar
Tiagovito
As the title says I'm manual swap my mini, after dealing with auto transmission problems I decided to swap it. and removing the engine to do it so.
With the engine out should I do a timing chain service and replace the head gasket? Even though it's no giving me any sings of failure? Engine as 180000km and been well maintained.
Also is anyone interested on me to document the process?
Old Nov 7, 2024 | 10:35 AM
LukasH's Avatar
LukasH
Service is never a bad thing and with that milage I would do the timing chain kit. Personally I would leave the head gasket alone as "if it ain't broken don't fix it".
Also I love to follow threads with progress updates. The NAM community is great and very supportive if you run into trouble during your adventures.
Old Nov 7, 2024 | 12:34 PM
ssoliman's Avatar
ssoliman
i'm tuned in
Old Nov 7, 2024 | 03:12 PM
cooper48's Avatar
cooper48
I would consider also replacing the camshaft sensor o-ring, front & rear engine seals and the water pump if it hasn't been replaced previously. You'll have easy access to all these with the engine out and it will save you grief in the long run.
Old Nov 7, 2024 | 04:12 PM
Tiagovito's Avatar
Tiagovito
Thanks for your advice! Im going to the timing chain at least. As for the timing chain kits there is any one popular often recommend? There is quite few options.
Old Nov 7, 2024 | 04:14 PM
Tiagovito's Avatar
Tiagovito
Last year I replaced water pump and camshaft o ring (was definitely leaking!) when I did the supercharger service
Old Nov 7, 2024 | 08:47 PM
LukasH's Avatar
LukasH
As I am from Europe my options differ from the USA people around here. But since you stated your mileage in km I think you are too.
I would go for a Febi or INA one, including the sprockets.
Boogers
Aug 12, 2019 10:55 PM
Louis Demers
15
Mar 9, 2019 07:50 AM
miniaway
Oct 16, 2015 01:03 PM
fm.illuminatus
Feb 26, 2009 05:55 AM
