R52 Brake Sensors
Old Oct 24, 2024 | 09:10 PM
AjaxOfTheRockies's Avatar
AjaxOfTheRockies
Brake Sensors
Got my first Mini in July - 2006 R52 164K miles.
I'm replacing brake pads this weekend and wanted advice about replacing the sensors. Should I do those while everything is apart?
Thanks!
—A
Old Oct 25, 2024 | 04:40 AM
Jason Cornelius's Avatar
Jason Cornelius
Thanks!
—A
Yes, you are there and probably going to break the old one.
Old Oct 25, 2024 | 05:05 AM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
OTOH, if you're enough of a "wrench" to do your own brake job, then you're probably going to stay on top of the condition of your brake pads. If that's the case, just tie back the old sensors with ty-wraps. They don't send a signal as long as they're intact.
Old Oct 25, 2024 | 05:09 AM
Jason Cornelius
I’m not running them in mine either, but I wasn’t going to suggest it.
side note if you do break one, just connect both wires together and tuck out of way, stupid front sensors 😉
Old Nov 2, 2024 | 04:08 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
With an R52 if the brake pad warning light is not on, you can reuse the sensors and the light will stay off.
You only need to replace them if the warning light is on.
njaremka
Feb 5, 2018 11:40 AM
njaremka
Nov 5, 2017 07:44 AM
Powashiftin
Tires, Wheels, & Brakes
Nov 23, 2011 09:28 PM
pimpedout97x
17
Feb 20, 2008 05:17 AM
