New to mini : fualt codes, engine check light
Old Oct 17, 2024 | 12:20 AM
Clubman Kirill's Avatar
Clubman Kirill
Hi all! New in this mini world and recently bought a 2011 clubman cooper s. 167k kilometers. Love the way it handles and pulls. It starts good, no rattles or anything else except the noisy ticking of the fuel injectors. There is however a few faulty codes coming up when plugging in de OBD reader.
Codes are:
2C58
2D60
3786
After a bunch of googling I'm now aware that there's something wrong with the exhaust VANOS. Either it being dirty or just broken. Giving me 2D60 and 2C58 as a result of 2D60. That's correct right? I'm getting a look at this.
Then there's 3786 which tells me there's a broken cirquit in the auxiliary waterpump area. I'm not sure what this means? Does it mean the whole pump isn't working or is it as simple as a sensor?
I did also notice the cooling fan isn't coming on at all. I don't know if the two problems are connected but I do know when I pull of the connector of the water temp sensor in the metal elbow thing (to the right of the cilinder head), the fan jumps on. And only then and at full speed. Again not sure if it's just the sensor, or something else. I did order a new sensor which will come in today and I'll be installing it later today.
At last i have the issue of when I shift thru the gears, I can't get a smooth 'one to another gear'. At first I thought I just had to get used to the transmission but I've driven the car for the past week now and it's still giving me some sort of hickup right after I selected a second gear and giving it throttle. It's like when you just let of the clutch quickly without giving it enough throttle. I don't know for sure but it feels like the throttle respons is off and a bit slow. Can this have something to do with the faulty VANOS solonoid? I've read a sign of a fualty or dirty one is slow throttle response because of just valve timing being off. Especially when accelerating hard, gear changes are harsh and it's like I'm new to a stickshift.. Which I'm definitely not.
A lot of questions! Thanks in advance!
Old Oct 18, 2024 | 07:53 AM
DogfaceSGM's Avatar
DogfaceSGM
Welcome to the world of MINI! I got mine almost three years ago and love it!
I can't answer most of your questions but, it you look up the codes on https://bmwfault.codes/ If you click on the hyperlink to the right of the code, most of the time it gives you some of troubleshooting for the code.
The below image is what you get when entering 3786
Johnson Rod
Sep 10, 2023 08:25 PM
pastatore
Apr 4, 2023 06:21 AM
Jcrowsom
Nov 8, 2020 03:41 PM
Hoyt06
May 27, 2020 09:41 AM
DerekZYX
Sep 12, 2018 11:33 AM
