How much brake line do I need
Old Sep 28, 2024 | 12:01 PM
Apexlate's Avatar
Apexlate
I want to replace rear hard lines from the joint on the drivers above the LCA back. I have about 18ft /216" of 3/16 cunickel tubing leftover from another project. Is that enough to do both lines?
Old Sep 29, 2024 | 05:30 AM
ernesto rex's Avatar
ernesto rex
I would have some more on hand to be safe. Especially if you plan on doing this without unions mid car.
Old Sep 29, 2024 | 06:55 AM
Apexlate's Avatar
Apexlate
I think I found it in an old thread.
"driver's side is 2654mm long and the Pass. side is 2650mm long"
Sounds about right to me.
Old Sep 30, 2024 | 07:48 AM
yep, they have different end i believe ones is M10 and one is M12. Make sure you get the right bubble flare as you would have to make your own.
https://www.northamericanmotoring.co...placement.html
Shawn Stanford
15
Jun 14, 2025 07:12 PM
Mcschobert
Aug 22, 2019 06:22 AM
bradnic
Feb 25, 2015 07:45 AM
micromini234
Jun 6, 2013 02:39 PM
MGear
Tires, Wheels, & Brakes
Jan 16, 2006 08:55 AM
