R56 Brake FLUID SPEC
Old Sep 21, 2024 | 10:37 PM
BUGG's Avatar
BUGG
Brake FLUID SPEC
Curious as to what SPEC should be used for Brake fluid flush in a 2019 JCW
Owners manual of course says nothing. What does everyone on here use. DOT 4 or DOT 5. MOTUL vs something else.
Old Sep 22, 2024 | 05:15 AM
Vanski's Avatar
Vanski
@BUGG ,
DOT 4 is the recommended spec for Minis and BMW’s unless you’re driving a McClaren, Pagani, and or Bugatti
Old Sep 22, 2024 | 09:48 AM
BUGG's Avatar
BUGG
Thank you Vanski. Looks like the Pentosin DOT 4 LV is what i'm going to go with.
Old Sep 22, 2024 | 10:03 AM
Gubi's Avatar
Gubi
Note that you're posting in the R56 forum so if you've got a 2019 you're in the wrong place.
That said, DOT 4 LV should be the right spec, yes. Pentosin DOT 4 LV will work fine but I like the Bosch ESI6 stuff: it's low viscosity, exceeds DOT 4 specs, and has a three-year replacement interval. It's relatively easy to find and not super expensive; I usually just buy it from Amazon.
https://www.boschautoparts.com/docum...id%20Flyer.pdf
Old Sep 22, 2024 | 03:05 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
As mentioned DOT 4. Also, be aware, DOT 5 is not compatible with DOT 4 spec fluid. Do not mix!
Old Sep 23, 2024 | 02:50 PM
BUGG's Avatar
BUGG
My Bad Gubi. i also have a 2013 S and Clicked in the wrong place. Ill take a look at the Bosch also
Old Sep 23, 2024 | 04:45 PM
cristo's Avatar
cristo
Alliance Member
Can use DOT 5.1 (glycol based like 3,4, etc.)
Can not use DOT 5 (silicone base).
DOT 4 has low temp viscosity spec <1500.
DOT 4 LV (or 4+) <750
DOT 5.1 < 900 (good enough for ABS, etc.)
I use Motul 5.1
DOT 5.1 ESP <750
chefjoseph
Mar 19, 2022 05:01 PM
Tires, Wheels & Brakes
Dec 15, 2015 04:24 PM
Sep 10, 2015 12:27 PM
fenderless 33
Aug 25, 2013 06:39 PM
Subliminal
Jul 5, 2011 11:04 PM
