R56 No Boost
No Boost
Hey All. I have a no boost issue with my 2010 JCW R56. I have smoke checked the entire system and everything is tight. I have replaced my DV and my Wastegate Boost Solenoid. I still do not have any boost. I am looking for other things I need to check that could be the cause of no boost. My turbo spins freely and does go up to 4psi at WOT. Normal driving the boost sits at -3 to -11PSI. There are no codes and aside from not having any boost, the car drives perfectly. I am at a complete loss, thinking it could be my wastegate?? Any advice is hugely appreciated.
Thanx!!
Thanx!!
I appreciate you posting those, unfortunately I’ve been through all those checks. I even used little zip ties to secure my vacuum lines. I replaced the vacuum solenoid and checked the tank for leaks. The only thing I haven’t replaced is the actual vacuum lines.
I’m worried that it’s the wastegate..
Drivetrain Boost Guage or Vac/Boost Guage...
Super_MINI
Mar 1, 2004 01:41 PM
