JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
Another JCW for your Enjoyment
Old Sep 19, 2024 | 09:28 AM
Krunch2020's Avatar
Krunch2020
Greetings, I recently purchased a late 10/2006 MCS with lots of JCW goodies on it. The car runs and drives and passed California smog. While replacing the CV axles I managed to pop out one of the sway bar links so I’m waiting for delivery on those. That top bolt on the carrier bearing is unreachable with my hands but I managed to get at it with a sidewinder wrench and a deep socket stuffed full of paper towel.
Sidewinder wrench
I’ve used the NAM vin Decoder and there’s no mention of the JCW kit. I have the JCW valve cover plate S16676.
The car also has JCW brakes, wheels, air filter box, honeycomb grills, front and rear badges. There is no red dot on the head. It also has aero side skirts. I haven’t removed the ECM to look for the sticker yet. The authentication document is not filled in.
Any info is much appreciated!
WMWRE33566TN28244
Kurt
Old Sep 19, 2024 | 01:56 PM
Hello,
This is what it has:
Model Designation
MINI R53
Date of production
20.10.2006
Color
CHILI RED (851)
Upholstery
STOFF/LEDER MOLETTE/TARTAN ROT/SCHW (FDTN)
Drive
FRONT
Type code
RE33
Model
COOPER S
Series
M R53
Body
3 doors
Steering
L
Doors
EC
W11
Displacement
1.60
Power
125
S463A
Interior surface Alloy Patina
S823A
Hot-climate version
S845A
Acoustic fasten seat belt reminder
S992A
Control of number-plate attachment
S228A
Sports suspension settings Plus
S563A
Light package
S481A
Sports seat
S262A
ITS - Head airbag
S470A
Isofix-System
S736A
2nd radio remote control key
S441A
Smoker package
S255A
Sports leather steering wheel
S493A
Storage compartment package
S876A
Radio frequency 315 MHz
S853A
Language version, English
S657A
Radio, BMW Business/MINI Boost
S546A
Revolution counter
S450A
Height adjustment, passenger seat
S692A
Preparation, BMW 6-CD changer I-bus
S650A
CD drive
S403A
Glass roof, electrical
S8SPA
Control unit COP
S925A
Dummy-SALAPA
S895A
Additional fan
S645A
BMW US Radio
S550A
On-board computer
S210A
Dynamic stability control
S319A
Integrated universal remote control
S521A
Rain sensor
S3ALA
John Cooper Works Kit
S5AAA
Rear fog light
S369A
MINI LA wheel, S-spoke 85
S431A
Interior mirror with automatic-dip
S383A
Roof and mirror caps, black
S520A
Fog lights
S534A
Automatic air conditioning
S1CAA
Selection of COP-relevant vehicles
S249A
Multifunction f steering wheel
S522A
Xenon Light
S2TAA
Differential lock 25%
More info here on those 2 options:
https://www.northamericanmotoring.co...l-jcw-kiy.html
Old Sep 19, 2024 | 07:53 PM
Krunch2020's Avatar
Krunch2020
Pleasant surprise!
Not only did I discover she’s a factory JCW with limited slip but someone has been busy installing a new alternator.
Alternator
Now that the AC compressor is accessible I can replace the clutch coil and do some cleaning. There’s a mess on the radiator side of the engine.
Kurt
Old Sep 20, 2024 | 07:03 AM
Hope that information helps.
Old Sep 20, 2024 | 07:38 AM
Jonny's Avatar
Jonny
Many of the Certificates are left blank, especially on factory JCWs. No need to fill it in. Proof that it’s a JCW is on the build sheet, as factory kits are listed there as option 3AL, dealer installed kits are not on the build sheet, and may be more important to have the certificate filled out at time of install so there is some documentation.
Old Sep 20, 2024 | 08:01 AM
Krunch2020's Avatar
Krunch2020
Thanks Jonny. The certificate I have appears to have been purchased more recently anyway. I don’t need or want a fake certification.
And many thanks to ECSTuning for running the vin. Order placed. 😁
Today I’ll clean the mess and replace the crank position sensor o-ring and replace the AC clutch coil. I’m tempted to pull the supercharger for oil service while I’m in this far but I will leave that for a winter project. I want to do some autumn driving!
Old Sep 20, 2024 | 07:00 PM
Krunch2020's Avatar
Krunch2020
What an oily mess.
The crank position sensor leak created a huge nasty mess typical of British cars from the 1960’s. After an hour of cleaning I got the AC clutch coil installed. It was a bear getting the pulley off and was time consuming. Hopefully it will hold vacuum and will be go for recharging.
The crank position sensor had to be excavated out of the oily dirt accumulation with a large screwdriver and a putty knife. I certainly don’t want another BMW o-ring since it’s a guaranteed failure after 5 years. Am I pissed about a $.10 part?
Anyway the project is moving forward.
Old Sep 21, 2024 | 01:39 PM
Krunch2020's Avatar
Krunch2020
What is the little (1” across) dome shape thing on the top of the 6 speed just behind the front passenger (USA) tranny mount bolt? I can’t get a good photo of it from the front. It’s weeping oil out of it and maybe has popped out 1/16” since I can see bronze or brass color.
I suspect it’s a job for this winter when I replace the mounts.
Old Sep 22, 2024 | 09:48 AM
Krunch2020's Avatar
Krunch2020
Ok, I can see two hex bolts (nuts?) under the 6speed transmission mount. One of them is loose. I suspect there may be preload on it. I’m going to tighten it gently with a long screwdriver and a hammer. Mounts will be replaced in a few months and I will get the Bentley book by then and hopefully identify them.
Kurt
Old Sep 23, 2024 | 09:14 AM
Krunch2020's Avatar
Krunch2020
Torque me up.
I found a photo that clearly shows the bolt and nut in question:
Looking for torque values on the nut and bolt below the throttle body on top of the tranny.
Old Sep 23, 2024 | 09:27 AM
A383Wing's Avatar
A383Wing
My '06 R52 is also a factory JCW, there is no sticker on the ECM, but the build sheet also has the 3AL kit as well...my car was made 9-13-2006, the plaque number is 16060
Bryan
Old Sep 23, 2024 | 08:17 PM
Krunch2020's Avatar
Krunch2020
Thanks for that Bryan. Apparently they kept making the 2006 R53 well into November and sold them concurrently with the 2007 R56. The convertible is another story I’m learning.
Kurt
Old Sep 23, 2024 | 08:27 PM
A383Wing's Avatar
A383Wing
Kurt
The R52 convertible was made through the 2008 model year.....it was still supercharged as the earlier years
Bryan
Old Sep 23, 2024 | 09:11 PM
A383Wing's Avatar
A383Wing
Here's a couple sites you might find of interest....first one is probably the most up to date registry for the JCW cars.....the second one is a site to get any JCW stickers that are missing from your car
https://www.thejcwregister.com/
https://www.kamikazedecals.co.uk/
Bryan
Old Sep 26, 2024 | 11:40 AM
Krunch2020's Avatar
Krunch2020
Getrag MT 285
I’m still searching because puzzle. What are the torque values on this nut and bolt?
Old Oct 7, 2024 | 05:37 PM
Krunch2020's Avatar
Krunch2020
Power steering Line
The power steering line is touching the sway bar.
It appears to be routed through the guide with rubber protection on it.
Is it supposed to be on the other side of the rubber?
Old Oct 29, 2024 | 06:57 PM
Krunch2020's Avatar
Krunch2020
Dropped the subframe
New tie rod inner and outer
Old Oct 29, 2024 | 07:02 PM
Krunch2020's Avatar
Krunch2020
Power flex control arm bushings
Control arm bushings and tie rod ends.
Old Nov 12, 2024 | 10:11 AM
Krunch2020's Avatar
Krunch2020
Subframe ready to reinstall
Subframe with new inner and outer tie rods, inner ball joints, new power steering hoses, control arm bushings.
Old Mar 5, 2025 | 05:08 PM
Krunch2020's Avatar
Krunch2020
Rear End Bushings
Hi All, I’m not a race car driver but I don’t mind mild street car mods. The ‘06 JCW came with Enkei J10 17” wheels and Conti Extreme Contact Sport Plus 205/45 ZR 17 tires. I’m preparing for a rear end bushing refresh.
I purchased a Whiteline 20mm sway bar since it was available locally. The Powerflex trailing arm bushings are arriving with new sway bar end links tomorrow. I’m sticking with stock control arms from Delphi.
All this is is prior to an alignment and summer fun!
Kurt
Enkei J10 with Conti Sport Plus tires
Old Mar 6, 2025 | 03:48 PM
Krunch2020's Avatar
Krunch2020
Got Parts?
Rear suspension 91k service.
Old Mar 13, 2025 | 11:26 AM
Scoobaru2010's Avatar
Scoobaru2010
Be careful with trailing arm bushings. Its highly advised not to use poly bushings as it can cause things to break. I left my powerflex trailing bushes sitting in the box!
Old Mar 16, 2025 | 04:10 PM
Krunch2020's Avatar
Krunch2020
Trailing arm bushings
I’m surprised to hear this. How would accurate location of the trailing arm motion cause any other part to fail?
Old Mar 24, 2025 | 07:18 AM
Scoobaru2010
I was as surprised as you, apparently the weak point is the bolts will walk themselves loose damaging the threads or shear the bolts off completely. Mainly because a lot of these bolts are "one time use" in the rear end, especially if you've converted to R56 trailing arms. I personally went with R56 trailing arms with standard bushings and upgraded every other bushing to poly back there. To each their own, i just wanted to chime in as this forum post below deterred me from installing poly trailing arm bushes even though there sitting on a shelf.
as taken from another mini forum
https://www.mini2.com/threads/rear-t...bushes.347601/
Old Mar 24, 2025 | 11:42 AM
Krunch2020's Avatar
Krunch2020
Rear Trailing Arm Bushings
Thanks for that! There is a note in the Bentley manual on cars from 05/2003 about the self tapping bolt that goes through the bushing. They say to tap out the hole but don’t mention replacing the bolt. I think a standard threaded bolt of the correct grade with thread locker is a good idea.
I’m using Powerflex purple bushings which are quite compliant and am not planning to track the car so not too worried about breaking bolts.
I put off the project because the weather is too nice. Must drive.
Kurt
