Electrical Two plug connector to One plug connector fan mod?
Question:
Can an (early) R50 2wo plug fan be rewired into/for an R53 one plug fan and be made to work?
Many years ago before I really knew a lot about Mini's (e.g: the difference between an R50 & an R53); I'd purchased a brand new radiator fan as a (future) pre-emptive measure.
It's been sitting in it's box (7years), still sealed in theromo-wrap. While doing a little parts arranging today, I'd noticed the part # on the box: Dorman pt# 620-902. It is a 2wo plug. I have an '04 R53 w/ a one plug.
Can the wiring mod be done or just waste time?
Thanks in advance,
Thanks in advance,
If you remove the relay from the assembly you'll be able to make it work. I can't give specific instructions but you'll just want to rewire it the same as a one plug fan. The motor and resistor are the same.
Ah - I wish someone would have responded sooner.
I recently gave away the (brand new), R50 (2wo plug) fan assembly away to a stranger I'd met with a 2003 R50.
But, Hey - If it wouldn't be too much trouble if you could post the procedure for others - That would be great!
Thanks!
Thanks!
