Running temp.
Running temp.
Just wondering if these temps are normal. I drove it about 20 miles then parked, went in store for about 5 min. Smeeled a faint, like rubber, smell...
Inside Temperature, DME Control Unit. 124° F
Air Inake 96.80° F
Engine Temp 230° F
Engine Oil Temp 219° F
Air Inake 96.80° F
Engine Temp 230° F
Engine temp is too high. It's possible that your fan is not operating properly. It's also possible, if you have a Gen1, that your crankshaft pulley is separating which would cause the rubber smell. It has a rubber core that over time separates from the pulley. That allows the center to spin but not the actual pulley (at the same RPMs). That would make all your accessories (alternator, water pump, supercharger, etc.) run slower than normal. That's also a good way to ruin your battery and get stuck somewhere with a no-start situation. Check it out.
