R56 N18 Coolant bleeder screw
Old Sep 1, 2024 | 05:29 AM
DogfaceSGM's Avatar
DogfaceSGM
I have to fill my coolant in my 2012 Coupe S R58 with the N18. There is no bleeder screw. Below is a picture of the bleeder screw location from my donor car engine (2013 Roadster R59 JCW) identifying its location on the thermostat housing.
Now a picture from my 2012 there is some sort of sensor in that location.
Without tearing everything apart I looked all over and couldn't find it. Anyone know what the deal is?
Old Sep 1, 2024 | 07:49 AM
Northern's Avatar
Northern
I can't find a bleeder mentioned in the TIS for the N18 at all.
The coolant fill & vacuum bleed procedure lists some cars as requiring manual bleeding, but the N14 and N18 aren't listed.
The RWD variant, the N13, is listed, and has a bleeder on the top of the expansion tank, but neither Mini variant do.
Old Sep 1, 2024 | 10:01 AM
DogfaceSGM's Avatar
DogfaceSGM
Both engines above are N18. 2012 S and a 2013 JCW
Old Sep 1, 2024 | 10:29 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Should be right next to that sensor, but looks like it might be under the fuel pump.
https://assets.ecstuning.com/product...8832_x800.webp
One of the best investments I made was a vacuum coolant fill tool.
Old Sep 1, 2024 | 04:33 PM
DogfaceSGM's Avatar
DogfaceSGM
That is exactly what the one on the JCW engine looks like. I used everything but a mirror to try and see it. I don't think it is there. Might have to invest in a vacuum tool.
Old Sep 2, 2024 | 05:36 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
The first time i used the vacuum tool, it took me longer to get everything set up than it actually took to fill the cooling system. It was an amazing experience.
Old Sep 3, 2024 | 02:17 AM
kerwooddr's Avatar
kerwooddr
Veteran: Navy
Of no less importance than solidly filling the coolant system is the vacuum test, especially after doing component replacement, such as the stupid water-pipe/thermostat assembly. Pull a vacuum on the empty coolant system and watch to see if the lower radiator hose remains collapsed for more than a few minutes. If the hose stays flattened, you know that all of the gaskets and o-rings are in good shape and you will have no leaks.
Old Sep 3, 2024 | 04:18 AM
DogfaceSGM's Avatar
DogfaceSGM
I actually purchased a coolant vacuum filler. It will be here this PM. The only coolant components removed were hoses so I hope I don't have a leak. Won't hurt to check it though.
Bean0709
R58 :: Coupé Talk (2012+)
Apr 15, 2024 01:54 PM
hpux1560
Jul 7, 2022 10:15 AM
m3j0m
Nov 18, 2021 10:59 PM
dube53
Mar 24, 2016 02:47 PM
Gipper
Aug 8, 2015 05:39 AM
