R56 Is my turbo working?
Old Aug 31, 2024 | 05:23 AM
gimmea250swb's Avatar
gimmea250swb
2012 JCW. I've got no warning lights, but I just realized I'm not getting the acceleration that I think I used to. I could be imagining it. I don't hear the swoosh/whistle from the turbo like I thought I used to - or it's not nearly as noticeable as it used to be.
What can I do to confirm the sucker is sucking?
Old Aug 31, 2024 | 06:30 AM
DogfaceSGM's Avatar
DogfaceSGM
If you have an ODBII Bluetooth device, connect it and use an app Like Torque Pro or whatever flavor you prefer to display boost. That would be the quickest easiest that I can think of.
Old Aug 31, 2024 | 08:17 AM
gimmea250swb
awesome, I’ve got one. Good thinking
Old Sep 1, 2024 | 05:59 AM
DogfaceSGM's Avatar
DogfaceSGM
Did you connect it and find out anything?
Being it is a 2012 JCW, you have the N14 engine. How many miles are on it? I have read many threads that refer to loss of power due to the valves needing walnut blasted. Perhaps that is your issue.
Old Sep 1, 2024 | 06:22 AM
gimmea250swb
Not yet. I've got the blue driver bluetooth and it' doesn't do boost. Looking online, it looks like I can do MAP and ambient pressure and get those readings. What am I looking for on the readings?
I don't think it's the valves, I had the engine apart about a year or two ago and all was well.
Old Sep 1, 2024 | 06:28 AM
DogfaceSGM's Avatar
DogfaceSGM
Subtract the two pressures = boost. When hammering on it boost should be somewhere between 12 and 18 lbs
I am not sure if the free version of Torque displays boost or not. Might try that.
Old Sep 1, 2024 | 07:15 AM
gimmea250swb
cool, so I should be able to connect the blue driver to torque?
Old Sep 1, 2024 | 10:00 AM
DogfaceSGM's Avatar
DogfaceSGM
The blue driver is just the ODBII Bluetooth device. Torque uses about any BT device. Try it with the free version to verify.
Rsh1282
Apr 26, 2019 02:03 PM
njaremka
May 26, 2017 05:55 PM
BooHAHA
Apr 20, 2011 05:14 AM
shadyyu
R55 :: Clubman Talk (2008+)
Oct 5, 2009 02:18 PM
