Electrical R56s retrofit JCW aero Kit (Rear Fog light connector issue)
Old Aug 19, 2024 | 10:40 PM
Donald M. Boyd II's Avatar
Donald M. Boyd II
Hello, I'm currently working on installing an aero kit on my 2012 R56S, and I've hit a snag with the rear fog lights.
The Cooper S has rear fog lights that serve a dual purpose, functioning as both reverse lights and brake lights. The wiring is routed to a board with two bulbs that handle these functions. I've noticed that there are three wires going into the connector for this board, which I believe are crucial.
As many of you know, the JCW gives you a choice between a brake light or a reverse light. From what I've seen, the right side functions as a reverse light, and the left side as a brake light.
However, when comparing the photos, the wiring doesn't seem to match up, and I can't figure out how to make this work. Aaron from Out Motoring suggested that my only option might be to rewire and attach the JCW connector, wiring the ground and reverse light for each side.
I've included some photos below. If anyone has experience with this, I'd really appreciate any advice.
Large fog light is cooper S and small one is JCW.
3 pin male connector on cooper s
Cooper S Fog Light housing on bumper
Cooper S female connector
Cooper S wire connection, ground, reverse, and break. I still need to find a trusted buddy to put in revers and not run me over so I can determine which is which?
JCW fog light
JCW 2 pin male connector I’m assuming ground and brake or revers
I can convert my cooperscooper s female socket to this two piece female connector to work with the JCW fog light.
The bumper I’m adding.
Old Aug 21, 2024 | 07:10 PM
DogfaceSGM's Avatar
DogfaceSGM
I am in the process of adding Aero to my R58 Coupe. In my research, I found this link.
https://www.northamericanmotoring.co...ar-bumper.html
It pretty much explains it.
Old Aug 21, 2024 | 07:54 PM
Donald M. Boyd II
Man coming through again clutch. Thank you.!!!
Donald M. Boyd II
Electrical
Nov 5, 2024 08:40 PM
Kyu Tae Heo
Dec 14, 2022 02:20 PM
Velothree
Factory JCW Talk (2009+)
Dec 4, 2018 12:04 PM
got_mini?
Oct 21, 2015 05:45 AM
zamfield
Feb 14, 2012 09:59 AM
