R50/53 R53 Carrier bearing bracket bolt size/thread pitch?
Old Aug 19, 2024 | 10:12 AM
nameuser's Avatar
nameuser
Hey all, my r53 decided to toss all three carrier bearing bolts into the void, allowing the passenger side axle to pop out just enough to immobilize it. Can't seem to find any replacement bolts anywhere so I need to figure out the right size before I head to the hardware store and buy a dozen different bolts in hopes of finding the right one. Does anyone here happen to know or have a set laying around?
Old Aug 19, 2024 | 10:32 AM
BlwnAway's Avatar
BlwnAway
Those are M8x30 (standard pitch 1.25), standard bolts would be fine, grade 8 would be better, if you can find them.
Just remember to loctite them. (Blue strength is recommended)
Old Aug 19, 2024 | 10:36 AM
nameuser's Avatar
nameuser
You're a lifesaver! I can't thank you enough. And yeah, definitely throwing some loctite in there, if I had done it the last time the axles were out this probably wouldn't have happened.
Old Aug 19, 2024 | 12:36 PM
OutlandishnessDue's Avatar
OutlandishnessDue
Torqued mine to spec but didn't use loctite. I'll go back in and do so!
Old Aug 19, 2024 | 01:35 PM
nameuser's Avatar
nameuser
Yeah man it happened at the worst possible time. Just changed all of my fluids and was headed out for a camping trip. Filled up and went home to grab the wife and the axle decided to pop out right across the street. If my luck was just a little worse id be stranded hundreds of miles from home.
Old Aug 19, 2024 | 02:53 PM
cooper48's Avatar
cooper48
Ace Hardware has all the Grade 8 bolts you'll ever need.
Old Aug 19, 2024 | 03:07 PM
cooper48's Avatar
cooper48
Also, #3 on the attached:
https://www.realoem.com/bmw/enUS/sho...diagId=31_0622
Old Aug 19, 2024 | 04:26 PM
Here2Go's Avatar
Here2Go
NAM Community Team
@nameuser Glad it wasn't worse!
Luckily my axle never popped out but I noticed the 3 bolts securing the carrier had backed out by a few threads.
Having never touched or worked on the carrier bearing - I'd thought it was unusual at the time but after experiencing some vibration upon acceleration; I only discovered the problem while under the car installing powerflex inserts in the lower engine mount.
Lying on my back, I just happened to look up and noticed the 3 bolts were loose.
Re-torqued the bots - no more vibration.
Loctite next time I'm under there
Old Sep 9, 2024 | 03:04 AM
AnthonyClark's Avatar
AnthonyClark
Originally Posted by cooper48
Thanks for the link, you made my day.
_louis.se_
May 18, 2024 12:06 PM
Minimark89
Tires, Wheels, & Brakes
Mar 20, 2021 04:57 AM
Tybo88
Aug 15, 2019 05:30 PM
tummi_gummi
Apr 14, 2014 05:39 AM
nkatsim
Oct 31, 2010 07:43 PM
