R50/53 after market fan+A/C
Old Aug 1, 2024 | 04:38 AM
daveking's Avatar
daveking
Hi
I fitted an aftermarket fan and would like to know if there is a fan trigger wire for the A/C in
the original fan loom plug and what color.
I was wondering if i could us the compressor connection.
Thank you in advance.
Dave king
Old Aug 1, 2024 | 04:46 AM
mrbean's Avatar
mrbean
The fan is controlled by the DME. So when you turn on the AC, it sends a signal to the DME which then triggers the fan.
There isn't a separate wire for this, it uses the same wires as it would for triggering the fan when the engine gets hot. If you've reused the original wiring harness everything should work.
*The stock fan is two speed, so if the new fan is only single speed then you might run into problems.
Old Aug 1, 2024 | 03:26 PM
BlwnAway's Avatar
BlwnAway
@mrbean is correct with regards to the wiring, there should only be a hot and a ground at the point of connection to the fan.
But... The fan is actually not a two speed fan, the low and high speeds are controlled in the wiring itself prior to the connection at the fan, low speed is simply controlled with a resistor that limits current to that wire, thus the limited speed of the fan.
The only thing should should need to be concerned with is the ability of your fan motor to operate at a lower current level without compromising the motor itself over time.
05R52
Apr 29, 2022 06:13 AM
Petrie_@yahoo.com
40
Jun 14, 2020 08:52 PM
navybsn
Mar 21, 2016 05:03 PM
lambspeed
Electrical
Jun 2, 2011 02:52 PM
diptenkrom
May 15, 2008 02:35 PM
