Electrical removed ac...how do i wire for aftermarket fan?
Old Apr 24, 2011 | 06:36 AM
lambspeed's Avatar
lambspeed
Never used my ac in my car ever. Last year had a little fender bender and removed all the ac components. I had the typical low speed fan failure and now no fans at all. thankfully I only have a short drive to work. Just need info if I can wire a aftermarket fan using factory harness. using the factory temp sensor to turn it on. second would be...will the power steering fan still turn on?
Old May 4, 2011 | 12:23 PM
Eric_Rowland's Avatar
Eric_Rowland
You can get a replacement fan for ~$70, no sense playing with a replacement that isn't designed to work with the system.
Old May 4, 2011 | 01:51 PM
chris.j.lamb's Avatar
chris.j.lamb
The cooling fans are controlled by the Engine ECU, it switches the 1 OE fan at low & high speed using 2 relays and a resistor.
Checkout http://www.bmw-planet.com/diagrams/release/en/index.htm for wiring
Old May 4, 2011 | 02:59 PM
lambspeed's Avatar
lambspeed
so...all will work fine w no ac components?
Old May 6, 2011 | 06:51 PM
Eric_Rowland
I believe so. The fan reacts primarily to water temp - the AC is just an additional stressor which would make the fan turn on sooner than it would otherwise.
Old May 7, 2011 | 08:37 AM
ZippyNH's Avatar
ZippyNH
The car is sold otside the us without ac....that is why they sell a dummy pulley to replace the ac compressor....keeps the belt the same length...
Old Jun 2, 2011 | 02:52 PM
lambspeed's Avatar
lambspeed
problem is...the high pressure switch for the ac. if you disconnect it. fan comes on after start up and stays on. just trying to figure out if i should replace fan assembly w a aftermarket adjustable fan. or wire the harness for the high pressure switch to a toggle.
ltjpunk7
Sep 6, 2015 07:32 AM
kitty90034
Navigation and Audio
Aug 25, 2015 12:47 PM
Getrieben
Aug 15, 2015 09:09 PM
minipopkart
Aug 13, 2015 05:22 AM
