Massive missfire!
Old Jul 28, 2024 | 09:34 PM
Carlson08minicoopers's Avatar
Massive missfire!
I have a 08 mini s turbo has a cat less manifold changed 02 sensors then took for a long drive the next day was running it pretty hard then started misfiring got it limped home. Next day found a super nasty plug changed out all the plugs and it got a little better so I changed coil will start fine then will start missing them set p0300 and p0303. I changed 02 sensors to brand name ones and still hasn’t helped. Do you guys have any suggestions? High pressure fuel pump? It does smells really rich.
Old Jul 29, 2024 | 07:29 AM
Jason Cornelius's Avatar
Jason Cornelius
When I had my R55s I had to chase misfires for a month. New coils and plugs didn’t do it, had hpfp on hand, ended up needing to walnut blast the intake valves. Once they were done, misfires gone.
Old Jul 29, 2024 | 08:45 PM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
What codes do you recover using a tool that reads BMW/MINI fault codes?
Did you replace the upstream O2 sensor? If so, that's also something to check.
Old Jul 29, 2024 | 10:11 PM
I changed upper and lower o2 sensors and plugs
Xplct
17
Jul 22, 2023 10:11 AM
Bilo8792
Feb 12, 2021 03:48 AM
kayer56
Feb 6, 2019 08:17 PM
CrueExistence
May 2, 2017 04:40 PM
jeffl
Oct 9, 2016 09:23 AM
