R57 2 Questions: Battery & Brakes
Old Jul 20, 2024 | 02:23 PM
JAMADOR's Avatar
JAMADOR
Figure this would get more visibility & response here, than the R57 side.
Likely picking up a R57 from my dad, triple brown non-S, but it's been sitting for about a year & the battery is completely flat.
Question 1: Does the battery have to be 'registered' to the car when it's replaced? Is this something easily DIY?
The brake wear light was on when he was last driving it. He replaced the pads & the sensor, but the light stayed on
Question 2: How is the brake wear light reset? I want to say I saw somewhere there a button sequence to reset it.
I'll need to get it inspected before being able to register it, and it'll fail with the brake light on.
Old Jul 21, 2024 | 05:51 AM
Vanski's Avatar
Vanski
@JAMADOR ,
Try these steps:
Old Jul 21, 2024 | 06:01 AM
Vanski's Avatar
Vanski
@JAMADOR ,
As for the battery, do you have that square box on your negative cable? If so, your car has an IBS(intelligent battery system). If you’re just charging the battery back up, no need to re-register the battery. However if you’re getting a new replacement battery, then yes. You will need to register the battery. Any OBDII scan tool can register your new battery.
Old Jul 21, 2024 | 06:13 AM
JAMADOR's Avatar
JAMADOR
Thanks for both! The car [2010 R57] is currently an hour away from me, should know more soon.
Old Jul 21, 2024 | 06:18 AM
Vanski's Avatar
Vanski
No worries, give us a holler when you have a chance
Old Jul 23, 2024 | 09:32 AM
JAMADOR's Avatar
JAMADOR
Originally Posted by Vanski
@JAMADOR ,
Will a BlueDriver work for registering the battery to the car? I do have one of those. Otherwise, all I've got handy is a generic HS/MScan OBDII that I use for ForScan on my Fords.
Old Jul 23, 2024 | 02:43 PM
Vanski's Avatar
Vanski
@JAMADOR ,
After checking the specs of your Blue driver scan tool, your Blue driver doesn’t have the features to register your new battery. However, as luck would have it, Habor Freight ZR11 scan tool for $120 does have this feature to initialize your new battery. Check out the photo below:
Old Jul 23, 2024 | 03:49 PM
JAMADOR's Avatar
JAMADOR
Thanks, wonder of one of the auto parts stores can do it with their tool?
Would prefer to not add another tool, just for this, right now.
Old Jul 24, 2024 | 08:25 AM
JAMADOR's Avatar
JAMADOR
Well, looks like I'll be picking up that Zurich
Mini fee to register the battery at my closest dealer: $195
Battery with install & program from the dealer $500
None of the local auto parts stores can do it
Figure the code reader will be otherwise handy & good to have.
Old Jul 25, 2024 | 06:25 AM
JAMADOR's Avatar
JAMADOR
Another battery question.
H6 is the proper size for this generation Mini?
Old Jul 26, 2024 | 08:30 AM
Northern's Avatar
Northern
Some of these cars have IBS and some don't. Not sure what the logic is. If you don't have IBS, nothing is required after installing the new battery.
Brake pad sensor is a wire beside the pad that rubs against the rotor and grounds out once the pad gets thin enough. Nothing to reset inside the car, but If the light doesn't go out once the pads are changed, the 'sensor' is bad and needs to be replaced. Some people will say to replace the sensor whenever it wears through the wire's coating - if you don't, the worst that can happen is it gives you a false brake wear light at some point down the road.
Old Jul 26, 2024 | 08:34 AM
JAMADOR's Avatar
JAMADOR
Good to know. If no IBS, I can just return the scan tool I bought yesterday
On the brake sensor, it'll fail for inspection with the light on [for 1 more year, until TX drops the safety req for annual inspection]. IIRC, they replace the sensor when they did the brakes, will have to get a look at it all tomorrow when I get there.
Old Jul 28, 2024 | 09:30 AM
JAMADOR's Avatar
JAMADOR
Small update.
No IBS, so I didn't need the scan tool. Small win.
Drove the 65 miles gome without issue.
Cannot get into the svc menu, though. Did the process in post #2, get the dash light check, but never get to step 8.
Advice?
Old Jul 28, 2024 | 04:46 PM
JAMADOR's Avatar
JAMADOR
Got it
it's 0.0 & BC, not 0.0 & Dimmer
Didn't do the dash light check, but went right to the svc menu.
Was able to clear the maint & brake lights.
Rebound
Aug 28, 2022 06:51 AM
davidg5700
Jan 2, 2019 10:49 AM
jlm78
Nov 19, 2018 04:58 PM
Nat176s
Mar 15, 2018 03:59 PM
Chuck W.
Apr 27, 2009 04:09 PM
