2012 Countryman R60 -- issues
Old Jul 18, 2024 | 05:01 AM
tgsantini61's Avatar
tgsantini61
Forum,
I'll try to be direct. I’m currently experiencing the following issues.
Lights: -- Rear taillights not working. Brake lights and Reverse lights are functional. I've checked bulbs and harnesses with no obvious anomalies. Does anyone have (advise/experience), on (fuses/wiring), for this issue?
Horn: -- There are two units (speakers), for the horn. Can only use one unit because when the other is plugged in, the horn will continuously sound. Does anyone have (advise/experience), on fuses or wiring?
Air Condition: -- Having the same issue as in several posts. Oil chemical smell at higher speeds through vents. Does anyone have root cause, as no one post has a specific resolution?
Oil leaks: -- I have fixed all obvious oil leaks but engine still smells of oil. What have I missed ? EX: Fixed Valve Cover, Brake Oil Housing, Brake Vacuum Pump, Oil Pan gasket, No visible signs of oil.
Thank you for your responses….
gpetersttu
Sep 20, 2021 03:37 AM
Brandon Fluharty
Aug 22, 2021 11:01 AM
KumarS
Sep 6, 2016 07:01 AM
mrbug
R57 :: Cabrio Talk (2009+)
May 24, 2016 02:46 PM
rkj__
Feb 11, 2016 08:08 PM
