R56 9ca9 error code - lights issue
Old Jul 10, 2024 | 08:03 PM
Masseyred's Avatar
Masseyred
Hi. I'm having really funky lights issues. Some work, most don't. Scan of the car - FRM is throwing a 9ca9 fault code "Terminal 30A connection faulty". Any advice? I have no idea where terminal 30A is and google hasn't helped much.
Thanks!
Old Jul 10, 2024 | 08:35 PM
mkov608's Avatar
mkov608
The terminal 30g relay is in the junction box in the right footwell. The relay is 1068.
Old Jul 10, 2024 | 08:36 PM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
Any recent battery issues, battery disconnection, jump start, or water incursion?
Old Jul 10, 2024 | 08:44 PM
Masseyred's Avatar
Masseyred
The car is newcto me. Drivers footwell was full of water. Leak fixed. Frm was corroded. Replaced and had vin ported over. Same issues. Battery is new according to previous owner. Looks new. No idea about the history of the battery beyond that. At a loss what to check next.
Old Jul 10, 2024 | 08:46 PM
Masseyred's Avatar
Masseyred
I'm seeing an issue with 30A. Not sure how that differs from 30 g
Old Jul 10, 2024 | 09:15 PM
Maybe, maybe not
Community Builder
Did you do this^ work?
Old Jul 10, 2024 | 09:17 PM
Masseyred's Avatar
Masseyred
The vin i had ported by someone else. I did the rest
Old Jul 10, 2024 | 09:21 PM
Maybe, maybe not
Community Builder
The FRM reprogramming was faulty and/or the FRM connectors are corroded. Are the 4 FRM fuses behind the passenger kick panel good?
Old Jul 10, 2024 | 09:25 PM
Masseyred's Avatar
Masseyred
The fuses all seem good. I suspected the connectors might be corroded, but in tests they seemed ok. I asked the guy who did the porting over and he said only the vin info ports over. I have wondered if the programming is corrupted, but i lack the equipment to check that myself
Old Jul 10, 2024 | 09:30 PM
Maybe, maybe not
Community Builder
The FRM programming is suspect, but also inspect the FRM connector pins for corrosion and test whether battery voltage from the 4 FRM fuses reaches the FRM connectors.
Old Jul 10, 2024 | 09:32 PM
Masseyred's Avatar
Masseyred
Will do. Watch this space... and thanks!
pmanliu
Apr 7, 2018 03:23 PM
mona5255
Jan 29, 2014 08:04 AM
nick654377
Oct 24, 2013 02:10 PM
karlInSanDiego
Jan 3, 2008 08:53 PM
jody
Sep 20, 2006 01:53 AM
