Suspension Rear End bushings.
Old Jul 3, 2024 | 07:31 AM
R53Pete's Avatar
R53Pete
Rear End bushings.
I am slowly restoring my R53.
Right now I am pulling EVERYTHING from the rear end, subframe etc.
I am looking to replace all the bushings with poly. I have 8 bushings for the control arms coming.
What else do I need? 2 bushings for the sway arm? Top mount for shocks? What else?
Anything else i should replace while Im there?
I will drop the tank to change the oil filter and pump too.
Old Jul 3, 2024 | 08:06 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Here you go:
https://www.powerflexusa.com/shop/ca...2001-2006-1447
Old Jul 3, 2024 | 08:16 AM
R53Pete's Avatar
R53Pete
Perfect, thank you. Looks like I covered eveything. Now to see if I can fix the rear subframe. For a 20 year old southern car the subframe is a rusty horror show.
Old Jul 9, 2024 | 09:17 AM
R53Pete's Avatar
R53Pete
Whoo whee. Any one here remove old factory bushings? Its a stamped metal part with open "wings" and if I use a press I can easily bend it.
Old Jul 10, 2024 | 06:34 AM
spaktacular's Avatar
spaktacular
I haven't done this job yet, but everything I've read instructs you to remove the rubber with a torch, then cut the outer bushing casing with a hacksaw, then pry out.
FYI, you can also look here https://psbushings.com/product-categ...-cooper-02-08/ for a diagram of all the bushings in your car. They also have installation instructions located right on the product page.
Old Jul 12, 2024 | 07:55 AM
R53Pete's Avatar
R53Pete
I used a 1" hole saw to cut those batards out and now I am shopping for a metal cutting jigsaw to cut the outer metal bushing
Old Jul 13, 2024 | 11:10 AM
ghostwrench's Avatar
ghostwrench
I used a chisel to shove in there to keep the ends from compressing while I pressed the bushings out.
It went pretty quick and easy like this. Here is how it turned out:
Shotgun_banjo
Oct 18, 2017 01:29 PM
Madgepetto
Apr 19, 2015 07:13 AM
Mindspin311
Suspension
Apr 9, 2012 04:22 PM
Aeromax
Suspension
Apr 3, 2010 04:23 PM
bobbyharr883
Classic Mini Talk
May 28, 2009 07:18 PM
