F55/F56 Changing upper motor mount, change transmission mount too?
2016 F55 MCS Automatic - soon to be Stage 2
I'm in the middle of changing the upper motor mount and intercooler now. Should I be changing the transmission mount while the upper motor mount is disconnected? I read someplace (or maybe I made it up) that changing the transmission mount is much easier with the upper motor mount disconnected becasue you have more wiggle room with the engine.
I'll be doing a stage 2 tune in a few weeks probably, if that makes any difference.
Easier just to do both as the same time, especially if you are putting down some serious HP/TQ.
While I have you here, I'm was planning on putting in the power flex yellow inserts into the upper engine mount. With stage 2 level power, would I be better off putting in the black inserts or will the mount last with just the yellow inserts? It's a daily driver car. I have the yellow insert in the lower engine mount already. A long time ago I tried the black insert in the lower engine mount and I got a lot of shaking, I assumed that was just from the stiffer insert, but looking back maybe my upper mount was already destroyed so it was vibrating more than normal with the black insert.
Thanks! I got the the intercooler I'm putting in from you guys!
Yellow, the black is pretty sturdy and might cause a little more engine feedback, if its a track car do the black. Daily do the yellow.
Glad to help and thanks for the orders.
I have 2016 X1 with 40k miles, engine mount break like 3k miles ago, great job Germany. Tomorrow will try to replace, what i see on your movie it's pretty similar.
192.168.100.1 192.168.1.1
