F55/F56 Changing upper motor mount, change transmission mount too?
Old Jun 17, 2024 | 04:12 PM
NamBot3000's Avatar
NamBot3000
2016 F55 MCS Automatic - soon to be Stage 2
I'm in the middle of changing the upper motor mount and intercooler now. Should I be changing the transmission mount while the upper motor mount is disconnected? I read someplace (or maybe I made it up) that changing the transmission mount is much easier with the upper motor mount disconnected becasue you have more wiggle room with the engine.
I'll be doing a stage 2 tune in a few weeks probably, if that makes any difference.
Old Jun 18, 2024 | 06:44 AM
Easier just to do both as the same time, especially if you are putting down some serious HP/TQ.
Old Jun 18, 2024 | 07:25 AM
NamBot3000's Avatar
NamBot3000
Thanks for the response. OK, sounds like I'm doing both. I hate redoing work.
While I have you here, I'm was planning on putting in the power flex yellow inserts into the upper engine mount. With stage 2 level power, would I be better off putting in the black inserts or will the mount last with just the yellow inserts? It's a daily driver car. I have the yellow insert in the lower engine mount already. A long time ago I tried the black insert in the lower engine mount and I got a lot of shaking, I assumed that was just from the stiffer insert, but looking back maybe my upper mount was already destroyed so it was vibrating more than normal with the black insert.
Thanks! I got the the intercooler I'm putting in from you guys!
Old Jun 18, 2024 | 08:16 AM
Yellow, the black is pretty sturdy and might cause a little more engine feedback, if its a track car do the black. Daily do the yellow.
Glad to help and thanks for the orders.
Old Jul 1, 2024 | 12:52 AM
ahdyu's Avatar
ahdyu
I have 2016 X1 with 40k miles, engine mount break like 3k miles ago, great job Germany. Tomorrow will try to replace, what i see on your movie it's pretty similar.
192.168.100.1 192.168.1.1
rrsuby25rs
Feb 8, 2016 10:05 AM
Saltysalt
Sep 24, 2014 11:38 AM
Roz
16
Nov 26, 2009 06:43 AM
1FSTMINI
Jan 6, 2007 08:10 AM
spillman
Jan 27, 2006 10:17 PM
