2010 Cooper Periodically Stalls Out
Old Jun 10, 2024 | 04:39 AM
Y. A. Martin's Avatar
Y. A. Martin
I have a 2010 Mini Cooper and periodically it will either stall while trying to start up or when coming to a stop it then stalls out. When starting if you give it some gas before it stalls it then kicks in to idle and seems to work fine for a while. Would appreciate any help or advice. TIA.
Old Jun 10, 2024 | 12:44 PM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
What BMW fault codes are stored in the DME?
Also consider monitoring the fuel pressure when the problem occurs versus when it doesn't occur.
Old Jun 11, 2024 | 02:54 PM
Y. A. Martin
Hi,
I have two codes pending for the engine:
P144B
P115C
Thoughts?
Thank you again for helping me!
Old Jun 11, 2024 | 03:19 PM
Maybe, maybe not
Community Builder
Try cleaning the mass airflow sensor.
Old Jun 25, 2024 | 06:17 PM
Y. A. Martin
https://youtu.be/o90KcZRz95U?si=02_MH3lsmyAVEXIU
Cleaned the throttle body and the mass airflow sensor, replaced the brake vacuum pump on the side of the motor, did an injector cleaning and oil cleaning service and something of that seems to have fixed the issue.
dcantwell
Jan 20, 2015 10:11 AM
ignitionmodule
May 3, 2011 10:55 AM
Crashton
Mid-Ohio Motoring Club
Feb 26, 2010 01:19 PM
