Shift lock Relay (CVT) Input Low
Old Jun 7, 2024 | 11:20 PM
Hawkins's Avatar
Hawkins
Hello.
I had an EP warning sign on my cluster. the gear sensor the one mounted just on the gearbox and also did a gearbox service changed the oil and put the recommended oil. The LEDs on the gear shift lever are not working and when I engage a gear maybe R or D the car doesn’t move until I give it gas and it stops moving once i let go of the accelerator. Mini Gen 1 R50 2003
FAULT CODES:
1: 1826 DME Shiftlock Relay (CVT) Input low
2: 1611 DME Communication Connection, Gearbox Control Unit
What could be the problem and solution as well?
I really miss driving the mini haven’t driven it in almost 7months now
Old Jun 13, 2024 | 03:01 AM
ahdyu's Avatar
ahdyu
I was not looking forward to tackling this job, but was able to, step by step, dissemble the console, drop the exhaust, and switch out my damaged shifter for a salvage one. Yep, $150. -- you were spot on. Thanks again for sharing; really appreciate it!
snaptube vidmate
Old Jun 14, 2024 | 08:21 AM
Check this out first: https://www.northamericanmotoring.co...input-low.html
hackerboy
Feb 4, 2023 10:33 AM
mbowman
Oct 25, 2018 10:42 PM
metellica
Cooper (non S)
Dec 4, 2012 03:38 PM
matweekly
Jan 10, 2004 07:25 AM
minilifecrisis
May 11, 2003 07:16 PM
