Shift lock relay (CVT)- input low
Old Feb 18, 2015 | 09:47 PM
slide mini's Avatar
slide mini
Hello every body
In cluster showing EP & shifter no LEDs lighting while shifting
3 faults ahowing in scanner
1826 shift lock relay (CVT)- input low
1611 serial communication, gearbox control unit
0444 tank- venting system- open circuit valve switching circuit
I checked gearbox control unit connection it's fitting ok
I replaced gear oil
& I replace gear relay in inside box
Still there's EP in the cluster
Any help please
Thank you every body
Old Feb 22, 2015 | 05:34 AM
slide mini's Avatar
slide mini
No comments!
Old Feb 22, 2015 | 06:10 AM
05r50's Avatar
05r50
Giving you a bump to the top.
I haven't had to work on one but from reading threads in the past;
1. The CVT requires special fluid so make sure you get the right one
2. There is a specific "reset" process afterwards involving walking the shifter up and down the stock. Its documented here in one of the threads.
Good Luck.
Old Feb 22, 2015 | 07:59 AM
slide mini's Avatar
slide mini
Good Luck.
Thanks for your reply
Just now I fixed the problem
It's with the fuses box
Fuse no f3 cut every time I replce it, I used more than 10 new fuses
So I replace fully fuse box
Then shifter leds working and
Mini Cooper now driving fine, CVT TRANS speeds ok
Old Jun 7, 2024 | 09:42 AM
Wealthyking's Avatar
Wealthyking
Hello. Which fuse box? Engine cabinet or passenger?
khumpert
Nov 30, 2015 11:48 AM
theblackfalcon
Oct 11, 2015 09:49 AM
jziran
Aug 24, 2015 04:50 PM
Aug 12, 2015 01:24 PM
