R58 Lights/electrical
Old Jun 6, 2024 | 04:47 PM
Masseyred's Avatar
Masseyred
Lights/electrical
Hi, All. Just bought a 2012 Coupe S and there are some light issues (list below). The drivers footwell had bad water ingress (solved) and I replaced the corroded FRM module and cleaned all the connectors but problems persist. Any hints as to the source of my problems?
(Note - windows DO work)
Interior dome - no
Map lights - yes
Floor lights - yes
Lower instrument panel - no
Front l - no lights/turn at all
Front r - turn & daytimes yes (no hi/lo ctrl)
L & R fender turn lights - no
Rear tail l&r - no
Rear brake l&r - yes
Rear middle brake - no
Rear turn - l yes, r no
Front fog - l yes, r no
Rear fog light - l yes, r no
Rear license light - yes
Reverse light - l yes, r no
Old Jun 6, 2024 | 09:05 PM
DogfaceSGM's Avatar
DogfaceSGM
First I wanted to let you know, even though you are in the correct forum R58, the R56 forum gets more traffic "visibility". Most of the info, as well as parts on the R56 carry over to the R58.
Second I am not the most knowledgeable on the electronic side but have done a lot of research on this site. (This forum is one of the most invaluable tools I have when working on mine.)
Did you get the FRM coded to your car? I think I have read it is required when replacing it.
Old Jun 6, 2024 | 09:23 PM
Masseyred's Avatar
Masseyred
The guy who did it was able to port over the info from my old FRM.
And thanks for the tip about the rooms.
Old Jun 7, 2024 | 02:49 AM
kerwooddr's Avatar
kerwooddr
Veteran: Navy
If the old FRM was damaged, then data that was extracted from the old module could well be suspect.
Old Jun 7, 2024 | 08:07 AM
Masseyred's Avatar
Masseyred
I wondered that too.
Old Jun 7, 2024 | 11:00 AM
Yep, it might have not transferred or be corrupt. You can get a new one or refurbed and have a dealer flash it to Vin. That info is stored at the MINI dealer network and you would know it has the correct info.
AcidK1
Feb 10, 2022 11:03 PM
volksfragen
Electrical
Feb 5, 2021 08:17 PM
MarioKart
Electrical
Dec 5, 2006 07:18 PM
Esc8p2NeverLand
Electrical
Apr 3, 2006 06:41 PM
