Hpfp feed line problem?
Old Jun 3, 2024 | 06:58 PM
MacMini34's Avatar
MacMini34
Hi all,
Car is for sale so hpfp decides time to act up. Wonderful. Should be straightforward enough to replace so pump acquired and job started. Low pressure feed line was difficult to remove and now it can be pulled off by hand. Pelican Parts say it should be replaced each time and since it doesn't lock on firmly it is probably unsafe. Hard to see where it connects further down in the car. Is it easy to replace? Kinda hard to find anything on searching since "fuel line" brings up a ton of unrelated issues and "low pressure fuel line" brings up lots of low pressure pump issues. Bentley manual skips this bit completely.
Looking for pump options, I noticed rebuild kits from Latvia on eBay. Seemed pricey at ~$180, but I wonder if they're any good.
So far the only repair I've had go smoothly were the sway bar links.
MacMini34
Old Jun 4, 2024 | 08:10 AM
Hello, Most people just get the PSA OEM (made in czech republic) pump from us as it has a lifetime replacement warranty now.
I have heard the china one fail right out of the box, dont know about the rebuilds.
https://www.northamericanmotoring.co...ge-hpfp-4.html Post #91
DIY HPFP: https://www.northamericanmotoring.co...r-r56-jcw.html
Old Jun 13, 2024 | 10:36 AM
idickers's Avatar
idickers
The low pressure feed line is fairly easy to replace from underneath the car. If you jack the card up you will see the connection between the steel and flex feed line just above the subframe. Its awkward but you can reach up and disconnect from below.
Old Jun 16, 2024 | 12:42 PM
MacMini34's Avatar
MacMini34
Originally Posted by idickers
The low pressure feed line is fairly easy to replace from underneath the car. If you jack the card up you will see the connection between the steel and flex feed line just above the subframe. It's awkward but you can reach up and disconnect from below.
So, I finally could see it from above once I realized there is a vacuum(?) hose overlying it and I could just reach it with the usual scrapes and scratches along the way. But getting that connector off was darn difficult. I tried the push and pull method multiple times and then all of a sudden it popped off. New line went on and buttoned it back up and Barry fired right up. Took him on my usual jaunt route and all is well. Should keep him but with my insurance renewal coming up next month scared at what the rate hike is going to be.
I did jack the car up and put the left side on a jack stand, but a brief foray underneath and I didn't actually locate the line. Feeling uncomfortable under there I went back to the top method. Once again it would be much easier on a lift.
I got a 321D code on scanning which is Tank EVAP leak code, but hope it stays away and only was due to the fuel lines being open.
cheers
MacMini34
jcslocum
Sep 23, 2023 11:57 AM
gresh
Jul 15, 2020 05:37 AM
HHH
Apr 2, 2019 10:54 PM
genik
Feb 17, 2015 08:29 AM
baredm
Jun 8, 2012 08:40 PM
