R56 Replacing the Vacuum Harness with rubber lines causing low boost?
The shop replaced the Vacuum Harness (11-65-7-570-465) with rubber lines now I only see 17lbs instead of 21 as before. Would the replacement rubber lines cause that?
Vacuum Harness - Mini (11-65-7-570-465)
2007-2012 Mini Cooper Vacuum Harness 11-65-7-570-465 | Mini Parts Direct2009 JCW R56
thats why they replaced the OEM lines with vacuum rubber tubes
I have a theory that the thin tubing they used is collapsing under vacuum and therefore not keeping the waste gate closed.
Yes, you want those lines to be vacuum tubing. They don't have to be the OEM tubes, but they should be rated for vacuum use. If they aren't vacuum hoses, they can compress under operation and cause issues.
Yep vacuum use. It has to be robust and keep shape.
https://www.ecstuning.com/b-genuine-...e/11657570465/
21lbs of boost! I only get around 18.5 on good days with my S - stage 2 RPM. I chased this issue before and replaced my vacuum line with a new genuine line and still couldn't get north of 20. It did improve from 17 with the replacement but I am still on my original turbo so maybe wastegate issue? I have the update DV but the car is an auto. I wonder if auto and manual have different boost thresholds (ECU)?
Any other areas to look at?
I can confirm that using anything other than the stock lines or hard lines will result in lines collapsing and boost being reduced or cut off completely. I used some red vacuum lines a while back to replaced a cracked line and anything over 10psi would cause them to almost fold in half.
I thought it was a problem caused by something else until I recorded a video under the hood while driving. I replaced the lines with OEM lines and my boost was back. I would caution anyone considering replacing their lines to only use OEM.
to follow up.... I had to change out the JCW turbo,( worn wastegate pivot and others,look it up) I did not notice the gradual turbo degrading, Boy do I have boost /JCW MoJo now!
yep, but the degaded vacuum line caused some issues too, so it was hard to nail down
blu3town
May 12, 2019 07:19 PM
shanksamillion
Nov 2, 2018 11:14 AM
