R56 Replacing the Vacuum Harness with rubber lines causing low boost?
Old May 19, 2024 | 06:51 AM
JPMM's Avatar
JPMM
The shop replaced the Vacuum Harness (11-65-7-570-465) with rubber lines now I only see 17lbs instead of 21 as before. Would the replacement rubber lines cause that?
Vacuum Harness - Mini (11-65-7-570-465)
2007-2012 Mini Cooper Vacuum Harness 11-65-7-570-465 | Mini Parts Direct
2009 JCW R56
Old May 19, 2024 | 07:48 AM
JPMM's Avatar
JPMM
Old May 19, 2024 | 07:20 PM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
Vacuum leak at one of the connections?
Old May 19, 2024 | 07:37 PM
JPMM's Avatar
JPMM
thats why they replaced the OEM lines with vacuum rubber tubes
I have a theory that the thin tubing they used is collapsing under vacuum and therefore not keeping the waste gate closed.
Old May 19, 2024 | 07:59 PM
Maybe, maybe not
Community Builder
May be worth contacting ESC Tuning. They seem to be quite responsive to customers.
Old May 20, 2024 | 05:29 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Yes, you want those lines to be vacuum tubing. They don't have to be the OEM tubes, but they should be rated for vacuum use. If they aren't vacuum hoses, they can compress under operation and cause issues.
Old May 20, 2024 | 08:06 AM
Yep vacuum use. It has to be robust and keep shape.
https://www.ecstuning.com/b-genuine-...e/11657570465/
Old May 20, 2024 | 08:12 AM
JPMM's Avatar
JPMM
Ok We will see ,ordering the OEM line and will install Thursday. thanks for all the help
Old May 30, 2024 | 06:33 AM
JPMM's Avatar
JPMM
I decided my boost was there , under the right conditions, so I have not installed the OEM line for now. However I do have it and it is very robust
Old May 30, 2024 | 09:32 AM
N14isLife's Avatar
N14isLife
21lbs of boost! I only get around 18.5 on good days with my S - stage 2 RPM. I chased this issue before and replaced my vacuum line with a new genuine line and still couldn't get north of 20. It did improve from 17 with the replacement but I am still on my original turbo so maybe wastegate issue? I have the update DV but the car is an auto. I wonder if auto and manual have different boost thresholds (ECU)?
Any other areas to look at?
Old May 30, 2024 | 07:09 PM
JPMM's Avatar
JPMM
I have a FJCW that might make the diff
Old Jun 27, 2024 | 06:43 AM
JPMM's Avatar
JPMM
the non stock tubing came off. I need to replace it with the factory item. Where do the lines attached to? I cannot find any drawings showing the attachment points
Old Jun 27, 2024 | 08:07 AM
Hello,
This one of post number 9
https://www.northamericanmotoring.co...s-hardtop.html
Old Jun 27, 2024 | 11:44 AM
Raymo2u's Avatar
Raymo2u
I can confirm that using anything other than the stock lines or hard lines will result in lines collapsing and boost being reduced or cut off completely. I used some red vacuum lines a while back to replaced a cracked line and anything over 10psi would cause them to almost fold in half.
I thought it was a problem caused by something else until I recorded a video under the hood while driving. I replaced the lines with OEM lines and my boost was back. I would caution anyone considering replacing their lines to only use OEM.
Old Jul 10, 2024 | 08:28 AM
JPMM's Avatar
JPMM
to follow up.... I had to change out the JCW turbo,( worn wastegate pivot and others,look it up) I did not notice the gradual turbo degrading, Boy do I have boost /JCW MoJo now!
Old Jul 11, 2024 | 04:25 AM
Yoshimura 1's Avatar
Yoshimura 1
So, it was the worn wastegate that was causing you the issue.......
Old Jul 11, 2024 | 06:04 AM
JPMM's Avatar
JPMM
yep, but the degaded vacuum line caused some issues too, so it was hard to nail down
Old Jul 11, 2024 | 08:34 AM
Yoshimura 1
Okkkkkkay........cool you got it sorted out......
DJewell
Dec 17, 2021 03:35 AM
MrGrumpy
Jun 11, 2019 06:53 PM
blu3town
May 12, 2019 07:19 PM
shanksamillion
Nov 2, 2018 11:14 AM
fernflex
Jul 26, 2008 06:33 AM
