R56 Air bag light on after seat removal for carpet shampoo
Old May 7, 2024 | 07:02 PM
NateEspinosa's Avatar
NateEspinosa
Hey everyone,
did some research within already and think I may have an idea of what is going on but want a gut check before moving forward.
I pulled my passenger seat out to shampoo the carpet and after I reinstalled the seat and plugged it back in it’s giving me these lights.
I thought it might be a fuse if some water shorted the plug but can’t find where a fuse for it would be and no burnt fuses.
I have no codes so thinking maybe the weight sensor just decided to go out when I pulled it out.
Before I buy the bypass, does anyone think it could be something else?
Old May 7, 2024 | 07:57 PM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
There should be a stored code. What are you using to check for codes? Did you reconnect all connectors and not mix them up?
Old May 7, 2024 | 08:02 PM
NateEspinosa
I’m using a cheap OBD Link MX+
Yeah, I only unplugged the main yellow harness under the seat. I pulled it back apart and reconnected. Double checked the other plugs too.
Old May 7, 2024 | 08:24 PM
Maybe, maybe not
Community Builder
The act of unplugging the connector may have set the airbag code but it's no longer active. In this case, clearing the code may solve the problem.
I use Veepeak BLE with this app, which can read and clear Mini codes. What car app do you use?
Old May 8, 2024 | 07:43 AM
NateEspinosa
Tried clearing the codes this am, no luck. Still
getting the light. Might look into the app and code reader you use.
Old May 8, 2024 | 10:03 AM
white46's Avatar
white46
First of all, before removing the seat, you should have disconnected the battery.
You need BMW app that can specifically clear SRS light. Not all does it.
Old May 8, 2024 | 10:26 AM
NateEspinosa
Then how would I listen to the radio while I was cleaning the carpet?
Just joking but you’re right, was lazy and skipped that step.
So it needs to go to a dealership?
Old May 8, 2024 | 12:26 PM
Maybe, maybe not
Community Builder
If you like to do your own repairs, just buy an app that reads and clears Mini/BMW codes. The Car Runner ELM app cost me only $7.
tylewis
Nov 27, 2017 09:37 AM
stephanieusrey
Jun 22, 2015 05:40 AM
classey17
Sep 19, 2012 06:05 AM
s decourcy
Nov 1, 2009 06:38 AM
05DSMCS
Dec 15, 2006 03:04 PM
