Turn signal bulb not working immediately after re-install of the same one!
Old Apr 29, 2024 | 09:43 AM
lucadenhez's Avatar
lucadenhez
Hello!
I have a 2011 R56S, and I took out the front left turn signal bulb to try and find out what model it is for purchasing a silver bulb variant. The bulb worked completely fine, and I made sure to not touch it with bare hands.
After reinstall, the bulb does not work and there's a fast signal noise and green arrow in the cabin. I’ve made sure the connector is tight, flipped the orientation of the bulb, removed the rubber grommet temporarily, etc.
I just took removed and re-installed the bulb that was already in the right side, and now it doesn’t work!!
Any insight? Thanks!
Old Apr 30, 2024 | 11:30 AM
lucadenhez's Avatar
lucadenhez
Solved. Rotated bulb into socket while plugged in and hazard lights on. If you rotate the bulb until it clicks in, the bulb will not work. A slight counter-rotation has to be made for the metal contacts to touch.
TonyB
Jun 13, 2016 03:23 AM
stilix
Jul 26, 2014 07:46 AM
Boosty
Electrical
Oct 17, 2013 11:06 PM
rffranks
Oct 30, 2008 03:57 PM
budascribe23
Mar 9, 2008 10:46 AM
