R56 Does oil filter housing leak onto downpipe?
I've got a oil leaking running down onto my downpipe. I think its the oil filter housing because I think the leak is coming from above the oil pan. Is this typical for oil filter housing leak?
pic: https://imgur.com/a/2xe6LwN
Yep down the front on the engine. Looks near the downpipe further up on the block. If its just the bottom, its the oil pan gasket.
Thanks, I started removing the oil filter housing today but not sure how to remove it from the car. Theres a pump(not sure if its actually a pump) mounted to the housing with a electrical plug connected, any idea how to unplug it? Or should I remove the two bolts that are mounting it to the housing?
There's a couple of torx's bolts that secures the oil filter housing to the engine block......
When I replaced my gaskets I put the front into service mode.....this allowed me too easily
remove the housing and clean the area......the downpipe shield is blocking one of the coolant
lines.......
lines.......
one73ronin
15
May 24, 2015 09:13 PM
F55/F56 Oil Filter housing torque spec?
fenderpicks
Nov 4, 2014 03:47 PM
R50/53 Oil Leak - Any guesses?
Dizzy_Jenny
17
Oct 17, 2007 08:02 AM
