R50/53 Door Plug - Part Number?
Old Feb 27, 2024 | 03:28 PM
Rstodd's Avatar
Rstodd
I was working on the inside door of my Mini when I saw these "plugs" in the bottom on the door, inside. Its falling apart and there are two of them in the bottom of the door. When I pulled it out it kind of crumbled in my hands. It is a soft rubber not plastic. Are these needed to keep moisture and dirt out? I cant find the part number anywhere. Will a strong plastic tape do the same thing? Any insight is appreciated.
This side faces up in side the door
This is the side that faces down toward the ground
Old Feb 28, 2024 | 03:43 AM
Here2Go's Avatar
Here2Go
NAM Community Team
I'm sorry I don't have any part info.
However, I thank you for posting these pics!
I had found one of these plugs laying in the spot where I normally park. I had upgraded my door speakers months ago and cleaned up the interior door panel as well...
You can email ECS, ALLMAG, or if you have any salvage yards near your local - it might be a good place to start.
Old Feb 28, 2024 | 06:16 AM
Looks like maybe 31mm?
Here is 25mm
https://www.ecstuning.com/b-genuine-...h/51718126605/
Lots of various ones here: https://www.realoem.com/bmw/enUS/sho...diagId=51_5496
Old Feb 28, 2024 | 06:23 AM
ramjet77's Avatar
ramjet77
Do a search on Amazon for "rubber plug" and you'll find dozens of sources. Measure what you have; you will probably have to buy an assortment to get the ones that fit but they're cheap.
Old Feb 28, 2024 | 09:40 AM
cooper48's Avatar
cooper48
Go to Lowe's and look in their hardware section. They have all kinds of interesting parts including similar plugs.
Old Mar 1, 2024 | 07:36 AM
JABowders's Avatar
JABowders
Veteran: Army
How about a photo of where it came from...
Old Mar 2, 2024 | 12:59 PM
Rstodd's Avatar
Rstodd
Just got an Amazon kit. The hole size is 25.4mm. The new plugs are more like rubber vs the old plastic plugs. Worked perfect.
Old Mar 2, 2024 | 07:48 PM
cooper48's Avatar
cooper48
Not exactly on subject but thought I would pass this along. I bought a similar selection of brass crush washers from Amazon for oil changes - dirt cheap and they work well.
Old Mar 3, 2024 | 07:59 AM
JABowders's Avatar
JABowders
Veteran: Army
I think it is Part Number: 51718126605, Blind plug (D=25MM)
alconk
22
Jun 10, 2019 01:40 PM
carltdh
Sep 21, 2013 06:02 AM
blacter
Oct 19, 2009 04:03 PM
stratman977
Classic Mini Talk
11
Jul 26, 2008 10:56 PM
mrs.mini
Jan 8, 2008 06:27 AM
